Virtues Of Paralleled FETs?
Started by Paul Marossy, February 06, 2013, 01:43:43 PM
Paul Marossy
So that same noise rule applies to preamp tubes? I read somewhere that paralleled triodes cuts the noise in half, but I guess that was not quite right.
Brian did get back to me on that. It has to do with the sound of that combination not really anything else.
> If you use two devices in parallel, the noise does not go to half, it goes to 1/root 2 or 0.707.  You need four devices in parallel to get half the noise.
Right; but also you must multiply the *current*. Use 4X the current, in 4X the devices *or* one device 4X larger, get 1/2 the noise voltage.
Keep the same *total* current, the hiss advantage is little to none.
> what benefit is there to having the FETs paralleled in such a manner?
In theory, if matched, it is no different from using one JFET with twice the area, *or* one same FET with double the resistor values.
Even if loosely matched, the combination acts like one FET, with perhaps a small difference at the clipping zone (which may be why it is different in this use).
If badly matched it is in-effect the one active FET doing the work.
If Brian has found more mojo this way, more power to him.
