LPB transistor question
Started by alparent, February 15, 2013, 12:43:08 PM
alparent
I'm building a LPB to boost the output of a Kay tremolo. Works great but the 2N5088 (500 hFe range) I'm using gives me to much boost.
Tried a 2N3904 (300 hFe range) and it gives me just the right boost but adds a lot dirt (not a clean boost like a 2N5088/89)
What should I use to get the boost of a 2N3904 but the cleanness of a 2N5089?
Any suggestions?
theehman
Why not just add a trimpot to the output of the 2N5088 circuit and adjust volume to taste?
Ron Neely II
Electro-Harmonix info: http://electroharmonix.vintageusaguitars.com
Home of RonSound effects: http://www.ronsound.com
fx schematics and repairs
alparent
'could do that but I'm curious about the transistor.
Gus
Quote from: alparent on February 15, 2013, 12:43:08 PM
Any suggestions?
That seems odd to me the LPB is a circuit that should react close to the same with different transistor because of the design.  What are the base collector and emitter voltages referenced to ground of the two different transistor builds what is the measured  power supply voltage of both LBP builds.
pinkjimiphoton
i can definitely see the 5089 having more "headroom" and distorting less... but i would assume it would have more volume too.
weird!
as for volume, i gotta agree with ron...
a plain-jane volume control is pretty easy.
different transistors have different sounds. a lot of it comes from the gain, but some are quieter, some noiseier etc.
be curious too to see your voltages!!
two of the best guys you could hope for are on this thread, so listen to them..
ron and gus are ace!!
Slava Ukraini!
~Jack Darr
