N.C. stomp switches?
Started by timd, February 21, 2013, 07:21:51 PM
timd
I bought these, hoping they were normally closed switches:
http://www.taydaelectronics.com/electromechanical/switches-key-pad/stomp-switch/spst-momentary-soft-touch-push-button-stomp-foots-pedal-switch.html
I would have found out they were N.O. if I stopped to read the damn datasheet!
Where can I source a sturdy NC stomp switch? I have found them in varieties that would be sub-par for stomping on though, just not what I need...
Pyr0
I normally buy these ones, they are SPDT, so you can wire them up to be normally open or normally closed if you want.
http://www.taydaelectronics.com/electromechanical/switches-key-pad/stomp-switch/1pdt-stomp-foot-pedal-switch-solder-lugs-2.html
I used an 'x'-wing dpdt momentary in my echo base, has worked fine but hasn't seen enough abuse to know how well it will stand up over time. Small Bear have them but i picked a few up locally for not much money so you may need to hunt around to find a good deal.
dave
smallbearelec
I carry the NC version of the soft-touch momentary if you want that:
http://www.smallbearelec.com/servlet/Detail?no=1222
I also have the "X-wing" like the one at Tayda. However, it isn't as rugged a part as the soft-touch.
Regards
SD
