help with wiring a spdt toggle switch
Started by mordechai, February 24, 2013, 07:50:30 PM
mordechai
I have a spdt toggle switch from smallbear -- it has three solder terminals, and I'd like to use it to do a diode-lift mod for a Big Muff Pi circuit.  What is the best way to wire the terminals to the circuit board so that in one position the diodes are engaged and in the other position, they are removed from the signal path?
You want a SPST.
To use your SPDT as a SPST, ignore one end lug.
