Trotsky Drive Bright Cut Swtich - How to wire it?
Started by chumbox, March 03, 2013, 11:30:47 PM
chumbox
Hey
Looking to build Trotsky drive but no matter how much I ponder it I can't seem to figure out how to wire the bright cut switch or what sort of switch I need.  First switch attempt thus my confusion.
http://www.beavisaudio.com/projects/TrotskyDrive/
Any help appreciated.  I did a search already but it didn't really answer the basics of wiring a switch for someone with no idea.
RandomGlitch
I'd get a SPDT switch, which has 3 terminals making it easier to wire up.
Wire the 22nF capacitor leads to the middle and left terminal of the switch.
With a small piece of wire or component lead off cut, connect the middle and right terminal of the switch.
Connect the left terminal with a piece of hookup wire to lug 1 of the volume pot (ground).  -  That's on the right looking from the back, lugs at the bottom.
Connect the right terminal to lug 3 (on the left) of the volume pot.
That's it.
Hope this helps
chumbox
Thanks Random Glitch, I think I understand that.  Would this also work if I have a DPDT On On Toggle handy?
RandomGlitch
#3
Yes that would work.
chumbox
Thanks Random, totally appreciate both your replies.
RandomGlitch
No worries!  Actually my first reply was wrong.     :icon_redface:    Don't add the small wire between right and middle of the switch.
If you use a DPDT you can just ignore the 3 lugs on one side.
