Turning a LED on with a transistor
Started by alparent, March 07, 2013, 09:41:27 AM
alparent
I want to put an indicator light on my tremolo.
If I put a LED directly to the pulsing source it works only at high speed.
At low speed the LED turns off. I think the voltage is lower then what the LED needs.
Can I use a transistor to turn the LE on and off and use the pulse source to drive that transistor?
I'm at work now, but will try it tonight. Just wanted opinions.
are you, by chance, using an ean tremolo, in some form or other? the phase-shift oscillator output peaks at "a" frequency, and falls off either side of that freq. possibly, your osc is not putting out the voltage required for the led at the low freq end of the pot. you could probably use an emitter follower to drive the led.
" I will say no more "
alparent
It's for a KAY Tremolo.
Quote from: duck_arse on March 07, 2013, 10:14:42 AM
Show me how and I'll try it.
samhay
Look at the 'Blinking LEDs' thread. There is a post by deadastronaut (among others) that uses both an NPN and PNP BJT to do what you want.
Paul Marossy
I would like to add an LED to my original EA tremolo. Need to check out this blinking LEDs thread..
alparent
Looks exactly like what I was thinking.
alparent
Quote from: Paul Marossy on March 07, 2013, 11:55:11 AM
Look at the GGG EA Trem project, the modification document talks about adding a flashing LED. I did it and it works without a follower.
