TL07x series - Happy running off 18 volts?
Started by Ibanezsr500, March 16, 2013, 03:05:33 AM
Ibanezsr500
Hey guys,
Just wondering if the TL07x series is happy running off 18V? According to the datasheet 18V is the maximum it can take. Will it be happy at 18-19V? I'm using my Onespot with a Max1044 voltage doubler, so the output voltage is slightly higher than usual.
samhay
Datasheet says max supply voltage is +/- 18V. IF you are only using the charge pump to generate 0-18V, then you are fine as you will need to bias to half that and will effectively have +/-9V.
bukas
ashcat_lt
36V is the most it can take.  All voltage is relative.
Ibanezsr500
Cool, thanks guys. I only want to run it in 18V for a bit more headroom. It sounds like it should take it fine.
