Fuzz face popping! please help!
Started by Leepyringa, March 17, 2013, 01:57:54 PM
Leepyringa
Guys! Please help!
I built fuzz face using silicon bc109b with negative ground ! It sounds pretty cool BUT there are some popping sounds when it goes on or off  :icon_neutral:
I have pulldown resistor of 1 M Ohm at the start ... and it worked well in my other builds but not here  :icon_frown:
I've checked all the connections and everything seems to be ok!
I used this schematic from fuzzcentral http://fuzzcentral.ssguitar.com/fuzzface/fuzzfacenpnschematic.gif with 1M pulldown resistor going from input to ground before 2.2 uf cap
Any ideas, guys? Hope someone will help me!
rousejeremy
Does it still pop when you turn it off and on a few times?
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
Arcane Analog
Popping - as opposed to clicking or ticking - is nearly always caused by switching from one DC level to another. You need an output capacitor and a pulldown resistor on the output as well as the input.
Do a search on my post on popping/clicking/ticking/thumping in the last week or so.
There is an article on geofex about this issue. It's worth reading, as is the rest of geofex.
Leepyringa
rousejeremy , yes it does.
Arcane Analog , no i didn't.
R.G. , thanks! Forgot to look there first. ::)
Leepyringa
Well output pulldown resistor didn't work for me , eh  :icon_sad:
Maybe my NOS mullard tropical fish at the output became too leaky ? What do you think guys ?
Get out your meter and measure for DC on the input and output pins at the PCB in both bypass and effect setting, across those pulldown resistors.
It's more likely to be a soldering or wiring problem than a leaky mylar cap - which is what "tropical fish" caps are.
Leepyringa
R.G. , I checked all the connections again and resoldered suspicious ones
Measuring DC on the in and out gave me 7 volts in both engaged and bypassed  :icon_confused: I guess it's alright ?
It still pops
If the voltage on input OR output is anything other than 0.000000V, it will pop.
You have a wiring problem, or a short on the board that's letting DC through.
Leepyringa
Ok , thanks I'll check it one more time  :)
Leepyringa
#10
No unwanted contacts here
Input plldown resistor is on the right , volume pot of 500K serve as a pulldown resistor at the output ( adding pulldown resistor at the output didn't change anything , and then I read about volume pot at fuzzcentral) ... no unwanted contact between components has been noticed , I checked all with my meter
Filtering cap of 100uf , no battery provided
Fuzz pot
Volume pot
So here it is ...
I triple checked just everything and it still pops... what do you guys think? maybe electrolyric caps are bad?  :icon_sad:
voltage between in and out is still 7 volts ... though when bypassed it's 0
