Super Fuzz transistor pinout question
Started by limit6, March 27, 2013, 04:37:15 PM
limit6
Hey, sorry if this gets asked regularly.  But I'm going to build a Super Fuzz  :icon_biggrin: and per this effects diagram the pinout of the transistors doesn't reflect the pinout of a 2SC828.  So my question is, is the Super Fuzz build diagram wrong, or do I need to twist the two legs of the transistor to make this circuit perform properly with a 2SC828?  Another question I have is, does the jumper in the upper left hand corner going vertically connect the first, third, and fifth horizontal strips, or just the first and fifth?
LucifersTrip
Quote from: limit6 on March 27, 2013, 04:37:15 PM
yes.
if you match EBC of the transistor you have to EBC (E to E, B to B, C to C) on the layout, then you're good
if you look at the schematic, you can see exactly what parts connect to each other. look what connects to the 9V
the 10uF is not connected to 9V+ in your layout. The 47uF on your layout takes the place of the 10uF power filter (cap from + to -) in the schematic
always think outside the box
digi2t
2SC828`s with this layout - you`ll have to twist the B and C legs to match the layout.
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
limit6
Thanks Lucifer and Digi.  @Lucifer, I appreciate the critical thinking exercise.  I'm not great at reading schematics but I'm very eager to learn.
LucifersTrip
#4
Quote from: limit6 on March 27, 2013, 05:19:00 PM
the symbols (especially input/output jacks) may be confusing in the beginning, but remember, almost everything else is just lines connecting points to other points...nothing weird. The jumper you asked about is from 9V+.  On the schematic, 47K, .001, Q2C, 220K, 10K, 100K, 10K, 100K, etc all connected to 9V+...not the 10uF on the 3rd "strip". That's connected to expander lug 3, so the jumper goes from strip 1 straight to strip 5. edit: the blue dot signifies a connection.
good luck
pinkjimiphoton
if you can get the 2sc828's, definitely do so... this layout i tried building as well, and i did not get it going.
5088's etc don't work well in this circuit... and match the transistors in the octave section closely and you'll get the best octave up!!
dino hipped me to that... amazing difference. ;)
Slava Ukraini!
~Jack Darr
limit6
Didn't get it working?  Bummer.  Now I'm discouraged from using this vero.  As for the 2sc828, I already have a bag of a dozen and a half  ;D.  Which two transistors are used in the octave engine, and how to I test them to see if they match?
limit6
Also, I want more of a gnarly, muddy sound.  Were carbon comp resistors ever used in Super Fuzz circuits, or were they always carbon films?
digi2t
#8
Quote from: limit6 on March 28, 2013, 08:55:14 AM
This should answer you question (full page of many Superfuzz variants);
http://d.hatena.ne.jp/Billl/searchdiary?word=super%20fuzz
The greatest collection of pedals on the planet, complete with fantastic pictures. If there was any reason for me to go to Japan, it would be to hunt this guy down, and bow to him.
As for transistor gains, I used 2SC828R's, and I followed the gains spec'd in the diagram below;
As Jimi can attest, they worked out very well. I bought a bag of 100 828's quite cheap, and I easily found the marked gains sorting through them.
P.S. Superfuzz structure is also used in the Honey Special Fuzz. I used the same gains for the fuzz. Sounds great.
Dead End FX
pinkjimiphoton
always read the threads with the veros people post. not all are verified.
i built two on IvIark's layout. one never passed signal (i tried a plethora of transistors, including the 828's) and the other i finally got to work, but it wasn't right. both were identical, built simultaneously.
i finally gave up and built the old mike livesley vero layout, fired up the first time.
what ya wanna do in the octave section is match the transistors and the diodes as closely as possible. that will help make the octave pop.
you can use high gain transistors, but it won't sound as good.. glad ya got the 828's. it's a fairly easy circuit to fall in love with once it's working. ;)
Slava Ukraini!
~Jack Darr
limit6
Ok, I'm going to switch to this vero and picking up a multimeter that measures hfe (I want Q4 and Q5 to measure between 180-200 - yes?  These are the ones I want to match?).  Only thing I'm doing differently is using OA90 diodes, not OA91s.
Also, just ordered carbon comp resistors from tube depot!  Based on the schematic above, it says to utilize a 100k lin, and 100k log pot.  I have a dozen 50k lins.  Anyone tried the 100ks?  Any preferences?
digi2t
QuoteI want Q4 and Q5 to measure between 180-200 - yes?
Yes. The closer the match, the more pronounced the octave effect. You could also incorporate a trimmer, like this;
The 10K trimmer labelled "Ocatave Balance". This can take care of any mismatch, or if you wish, you could dial it in to your taste. Your call.
Dead End FX
LucifersTrip
a couple quick notes...
solidhex (fu manchu) gave voltages from an orginal
http://www.diystompboxes.com/smfforum/index.php?topic=64068.0
     C        B        E
Q1  6.01    .66      .117
Q2  8.88   6.01     5.41
Q3  6.23   3.27     2.72
Q4  3.1     1.7      1.11
Q5  3.1     1.67     1.11
Q6  5.75   .98       .361
The original (I think) schematic from Univox site shows 2SC828 in only the Q2 & Q3 positions and 2SC539's in the other.
http://transistor-spravochnik.ru/description/2SC828/17535
Shows min 65 hfe. I have some vintage 2SC828 and they all measure 80 - 130 hfe
http://transistor-spravochnik.ru/description/2sc539/17085
Shows 250 hfe typical. Unfortunately, I don't have any to compare.
These hfe's make sense in the Dr Lamp schematic that was posted. You can see Q1, Q4, Q5 have higher hfe's.
The weird one is Q6. On the Dr Lamp it's lower hfe and solidhex's voltage for Q6C is relatively high (5.75). I did a bunch of tests when I built my first one and you need hfe < 100 to get there. The higher hfe, the lower the collector voltage...I wound up putting a trimmer on Q6 since I could tell a difference when it was in the 4V range rather than 5V and I didn't want to have to choose...
digi2t
Yeah, Luce is spot on with the observation. Unfortunately the original 2SC828Q's are impossible to find. The only thing remotely close is the R.
2SC828's came in three flavors; Q (130-260), R (180-360), and S (260-520)
Although the R's are a bit higher gain, out of a pack of 100, I was able to find many in the 140 to 150 range, as well as everything in between the R range.
I used R's in my Honey Special Fuzz. The original sports the Q's as well, but I was able to match the R's for my clone. In a side by side test, the fuzz is very close to the original. I believe that the resistors (metal films rather than carbon comps) may have made the balance of the difference.
Dead End FX
digi2t
Just bought some 2SC829's, some B's (70-160), and some C's (110-250). The spec's are somewhat similar to the 828's, so I figure I would try them on the breadboard, and see what happens.
I report back when I have something.
Dead End FX
limit6
Wow!  Thanks everyone for being so extremely helpful.  I feel like wizards are bestowing powerful knowledge upon me.  With the mike livesley vero, which resistor gets substituted with a 10k trimmer to bias Q4 and Q5?
digi2t
Quote from: limit6 on March 30, 2013, 01:02:40 PM
No subs. The two 22K's that normally go to ground, go to lugs 1 and 3 of the trimmer now. The center lug (2) of the trimmer now goes to ground. The trimmer acts as a divider now to balance Q4 and Q5.
Dead End FX
limit6
Ok, hopefully my last question...  on the Mike Livesley vero, all electrolytics seem as though they don't have their orientation listed.  I did notice a very slight color band on the caps, all of them facing down except for C8, which has its band facing up.  Am I seeing things?  Do all negative ends of the 10uf caps face down, and C8 has its negative band facing up?
It takes a sharp eye to read that program's cap-marks.
You read it right.
Derringer
C1 and C16 don't correspond though
they're flipped relative to each other
