Crazy Larry
Started by The_Bloody_Omen, April 11, 2013, 12:00:21 PM
The_Bloody_Omen
Hay guys sorry to bother you again but I am having difficulty finding out where to put the negative side of this LED.
http://i.imgur.com/L9alnrq.jpg
Is it the hole directly to the right of it? Is that the ground? and how would one wire the input to this thing, is it just the "tip" to the INPUT hole?
Sorry for being such a nub cake.
Thank you so much for your time,
The_Bloody_Omen
armdnrdy
LED D1's cathode is connected to R6.
D2's cathode faces R15
Input jack tip goes to the input pad...but you are going to use a bypass switch right?
Note to Cliff Schecht:
There is a LED device in Eagle library GM Diodes that includes a package that depicts the flat side of the LED and a square pad for the cathode.
