Wits End.............
Started by richinva, April 21, 2013, 01:57:08 PM
richinva
Whatever wits I had are now gone......
Building a GGG WHRL.  Specs say IC
1=5.5 (4.04)
2=2.7 (.33)
3=2.7 (.304)
4=2.7 (2.03)
5=2.7 (2.03)
6=.01 (.001)
7=5.5 (4.04)
8=0.0 (0.0)
9=5.5 (4.04)
10=.01 (.001)
11=5.5 (4.04)
12=.01 (.001)
13=0.0 (.001)
14=5.5 (4.04)  (sensing a pattern here!!)
15=.01 (.001)
16=0.0 (.001)
I have debugged until I'm crosseyed.  Voltage drops before the IC.
Thanks for any help.
Rich
Mike Burgundy
This may help:
Way Huge Red Llama
schem:
https://www.generalguitargadgets.com/pdf/ggg_whrl_sc.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
whats your supply voltage?
looking at the schematic, pins 7,9,11 and 14 and 6,10,12,15 are okay, *assuming* your supply voltage is a little low. These are all unused inverters.
U2 (pins 5,4) looks okay.
U1 (pins 3,2) is odd. Looks like it's totally off. Can't see any obvious spots in danger of shorting to ground (assuming you used the GGG pcb layout)
richinva
Supply voltage is 9.45 right up until the second resistor, then it drops to 4.04.  If I use the case as ground, it is up to about 5.4 or so, which is where it should be, but can't seem to find the problem.  Grounds seem to check out......
richinva
So does this sound like a ground issue?  Absolutely no sound from the pedal, but am getting the pop from the amp when I plug it in.  Funny thing, plugging the 9v power into the back causes my DD-7 to light up...........
midwayfair
You're going to have to remove the circuit from the enclosure. You have to eliminate the enclosure as the source of the problem. After you've removed it, test the circuit on your test rig. If it's good there, figure out what's going on with the enclosure.
Pics will help.
