FA-I Boost IC FA1457 Equivalent ??
Started by HOTTUBES, April 21, 2013, 11:54:04 PM
HOTTUBES
I want to build this boost circuit , but i was wondering if a common op amp might work in circuit ??
Is there any other IC's that might work here ??
Thanks for any help !
smallbearelec
Quote from: HOTTUBES on April 21, 2013, 11:54:04 PM
If you allow for the difference in pinout, sure! This article:
https://www.smallbearelec.com/HowTos/BreadboardICDist/ICDist.htm
shows the use of a TL071. Half of a TL072 would also be possible. I set it up as a heavy overdrive, but you don't have to use it that way.
Regards
SD
HOTTUBES
So will a J201 swap in for the 2SK246 once you alter the pin out etc ?
Thanks for the link !!
smallbearelec
Quote from: HOTTUBES on April 22, 2013, 08:09:03 PM
Sure. You should also expect to have to re-bias when you change JFETs because they vary so much in Vp and IDss.
HOTTUBES
Sounds to me like it would be easier to just order the 2SK246 ....
Is a 2SK246 used in any other common circuits ?
smallbearelec
Quote from: HOTTUBES on April 23, 2013, 11:20:10 PM
Numerous older BOSS pedals used it, but there is nothing special about it. The J201 and others are cheaper and more popular. Anything you use will require that the drain resistor value be tweaked, usually with a trimpot. For more info on why and how, check out the article on the Fetzer Valve at Runoffgroove. I have been referring to that a lot as I experiment.
iq01221
U can try with j201+TLC2272. I've did it, and works trully great!
