Atari Punk Console Troubleshooting?!?!?!
Started by Canucker, April 28, 2013, 02:26:02 AM
Canucker
Can't believe I messed this one up but the amp doesn't lie. I've built a couple of them in the past using a different layout (the three pot version) but decided to try this two pot version.
http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=33686&g2_serialNumber=1
Here are the readings I'm getting off of it. Thanks in advance for any advice (and holding back your laughter!...but don't feel you have to).....
1=0.005
2=0.005
3=5.33
4=8.00
5=0.003
6=5.33
7=0
8=0.003
9=7.47
10=8.00
11=5.31
12=6.46
13=6.46
14=8.00
rutabaga bob
It doesn't work because the layout is wrong.  Pin 6 connects to pin 2, not 3.  I just lifted that pin 3 connection, and ran it to where C1 and R1 connect before pin 2.  Success!  If you like the APC, build the 'Cacophonator' - highly recommended!.  Larry
Life is just a series of obstacles preventing you from taking a nap...
"I can't resist a filter" - Kipper
Canucker
What would I do without you guys? Thanks!
Canucker
Made the change and now it sounds like a fart machine....not a constant tone unless its on its just above its lowest setting...time to scratch my head some more.  :P If I could control the farting that might be something but I can really only control the volume.
rutabaga bob
Wish I could help you further...mine worked like a champ after I discovered the layout problem.
