Extreme n00b question dc power jack unswitched
Started by edson, May 09, 2013, 10:46:09 AM
edson
I was quite sure that  the longer "leg" on those DC power jacks that are unswitched is positive. Well, I was sure that the longer one was positive...
But I've built the huminator from beavisaudio, and a looper pedal from beavisaudio, and they are both not working.. so I wonder if it has something to do with it...
Anyone who can shed some light on this.. :(
Thanks,
Edson
Govmnt_Lacky
Picture of the DC jack you are using??
Do you have a DMM multimeter? USe it to verify.
edson
Govmnt_Lacky
Quote from: edson on May 09, 2013, 11:05:25 AM
How do I check it with a DMM? Continuity?
Yep! Or ohms. One lead on the center pin and the other to one of the lugs.  ;) That will tell you which is which
edson
Quote from: deadastronaut on May 09, 2013, 11:12:42 AM
long pin is +
i use those all the time. ;)
Aww.. then I don't know what's wrong with my builds :(
I guess continuity also confirmed it... center to short pin, beeeep :) Center negative right? :)
/Edson
Govmnt_Lacky
Quote from: edson on May 09, 2013, 11:21:15 AM
/Edson
Yes. Your center pin should be negative. So your V- or Ground should be all connected to the center pin of the DC jack.
edson
Quote from: Govmnt_Lacky on May 09, 2013, 11:48:39 AM
OK. Thank  you. Well, here it is the other short pin, no center pin on these.
I'll guess something else is wrong with these super simple builds then... I have built more difficult things.. but seems like a true bypass looper and a huminator is too hard for me.. hehe.
/Edson
govmnt_lacky, you're the designated "read the debugging page"-typer this week aren't you?
granny at the G next satdy eh.
Govmnt_Lacky
#9
Quote from: duck_arse on May 10, 2013, 12:05:15 PM
Not yet on this thread!  ;)
Just trying to help someone figure out which DC jack lug is V+ and which is V-
@Edson
I do not think you have a center pin/lug on the BACK of these type DC jacks. The "center pin" I was referring to was on the FRONT.
- Turn on multimeter and set it to OHMS.
- Connect RED lead to the center pin on the front of the DC jack (where you would plug in your power adapter)
- Connect black lead to either of the lugs on the BACK of the DC jack
- Check meter to see if it reads 0.0 to 1.0 (anywhere in between) on the display
- If it does not, move black lead to the other lug.
- If you DO NOT get 0.0 to 1.0 on EITHER of the lugs or BOTH at the same time, then the DC jack is defective.
- Once you find the lug that reads 0.0 to 1.0, that is the lug that connects to the center pin (and should be your V- or GND connection)
- The other lug will be your V+ or 9V connection
Hope that helps  ;D
^ what GL said...
try not to overheat those dc sockets...they melt quite easily.....which may or may not be your problem. :icon_idea:
edson
Quote from: Govmnt_Lacky on May 10, 2013, 12:14:17 PM
@Edson
Hope that helps  ;D
Hmm ok. I get 1 on the long pin, and anything and everything on the short PIN. So it means then that the long PIN is GND and not positive as I first thought.. *confused*
/Edson
the long solder lug is definately positive..
the short lug is negative...the tip!..
ive wired up lots of pedals using exactly the same DC socket... ???
