5 DIN to 6.3 Jack on Tape Echo unit
Started by nth, May 11, 2013, 10:10:54 AM
nth
Hello.
This is my first post here and here's my problem.
Recently, I  got old tape echo unit and i want to replace 5 DIN connectors with 6.3 Jacks, but I can't figure out connections between DIN and Jack. I'll attach picture or current 5 DIN connectors wiring. I would like you to write me something like this :
OUTPUT:
Connect RED wire to the Ring of 6.3 Jack
GRAY to the ground
GREEN to tip
etc...
http://postimg.org/image/yyp9mxh57/
If you need anything specifier, let me know. Hope someone can help me with this problem.
nth
brett
Hi
Wikipaedia is your friend: http://en.wikipedia.org/wiki/DIN_connector
So you can see that 2 is the common ground, 1 and 4 are in and 3 and 5 are out.
I'm not sure what your diagram is suggesting. Do you have a 6.3 mm stereo socket or mono?
In any case, the body is ground, and connected to 2.
cheers
Brett Robinson
nth
Thank you for your answer.
I want to use mono 6.3 jacks. So to make it work that way, I have to connect middle pin , number 2, to ground of jack and other wires to the tip.
Am I correct ?
I know , that my questions seem stupid, but I really don't want to do any damage .
nth
Mike Burgundy
yes, as long as you use 4 jacks, or 2 stereo ones.
1 and 4 are INPUT L/R
3 and 5 are OUTPUT L/R
So get say two stereo 6.3 jacks,
wire one up
sleeve - 2
ring - 4
tip - 1
and the other
sleeve - 2
ring - 5
tip - 3
you now have an IN and OUT jack.
