beginner question about cap values equiv......
Started by dclark, May 11, 2013, 08:34:24 PM
dclark
hey there, I've just started building some things outside of the kit type project.  I've picked up a couple of pcb's here and from MadBean.  While shopping at Mouser for the parts I come to a hitch where Mouser does not seem to list caps at certain values, so there must be a standard equivalence chart to reference somewhere?
by this I mean I can find the 100pF caps there but not the 100n, 22n, etc.. whereby (xx)n seems to be a decimal value of (xx)pF or uF.  I ran across something on the net once that explained this but I have lost the link and now an at a loss as to how to source these parts.
When I go to Mouser and use the value field search page to find the caps i need there is no (xx)n choice.  Only (xx)pF, uF or Farad
help much appreciated.
Thanks for a great forum
D
Govmnt_Lacky
Anytime you see "nF" values, all you have to do is move the decimal point 3 places to the LEFT and it becomes "uF"
Example: 100nF= 100.00nF so.... 100nF = 0.1uF
Example: 2.2nF = 0.0022uF
Hope that helps  ;D
dclark
It does, and I thank you.  On some of these layouts a part may be listed as (xx)n.  I presume it has been shortened from (xx)nF?
D
Govmnt_Lacky
Quote from: dclark on May 11, 2013, 08:51:31 PM
D
Yes. You will often see them listed as XXn. It means nanofarads
Jdansti
To add to what Greg said, I'll throw pico (p) into the mix:
1000pF = 1nF = 0.001uF
Move the decimal point 3 places to the left to convert to the next higher unit and vice versa. For example,
0.01uF = 10nF = 10,000pF
totes
It is quite common that capacitors in the nF range are listed in pF or uF, for example 2.2nF = 0.0022uF = 2200pF
R O Tiree
Sadly, yes it is. You quickly get used to shifting the decimal place around, though.
...you fritter and waste the hours in an off-hand way...
armdnrdy
I've been known to take a gander at this chart from time to time.
http://www.justradios.com/uFnFpF.html
Especially when putting together a bill of materials list for a project while head nodding at 1:00 in the morning!
dclark
Gristlepig
This little piece of freeware helped me out immensely back when I was experiencing the same confusion.
It's also great for figuring out value and tolerance markings on capacitors and resistors.
http://www.electronics2000.co.uk/
The law, in its majestic equality, forbids the rich as well as the poor to sleep under bridges, to beg in the streets, and to steal bread.
- Anatole France
armdnrdy
I use this for caps.
http://www.muzique.com/schem/caps.htm
And this for resistors.
http://www.hobby-hour.com/electronics/resistorcalculator.php
I use the electronics2000 calculators for parallel and series resistance and capacitance.
They are all great time savers!
chromesphere
#12
My admiration goes out to you dclark, for using mouser on your first builds!  Some veterans are afraid of their system!
You will get used to converting capacitors values, left and right the more you work with them.  I usually write down the value, put a decimal place and then 'shift it' 3 to the left or right.  Helps me to visually see whats going on particular with large conversions, like 0.0000004 on the calculator to microamps for example :D
If you dont have one already you might want to consider a capacitance meter to confirm values as well.  Reading the 104's 103's and all sorts of other markings on caps can be confusing to begin with as well.
All the best,
Paul
Pedal Parts Shop                Youtube
