**The DIYStompboxes 10-Year Anniversary Contest Thread**
Started by midwayfair, May 22, 2013, 03:59:28 PM
Perrow
Quote from: samhay on August 29, 2013, 04:18:30 AM
Very nice Pelle. How do you like the circuit with the Ge vs Si transistors?
With Ge it's far more usable than I had it with Si, it had some insane gain with Si. Had my guitar volume on like 1 or 2 and still had extreme distortion, sounded quite good though. With Ge it cleans up rather nice if you turn down the guitar volume and it's far more responsive to how hard you pick.
Guess I could have searched my inventory for lower gain silicons and adjusted the collector resistors some to get the overall gain down, but why would I now that I've got my Ge's to work :)
Quote from: Perrow on August 29, 2013, 03:52:03 AM
I'm hoping there'll be a last place open for my entry  ::)
awwww...don't be like that,  group hug! :-*
samhay
That sounds fair enough, and is good to hear the Ge was worth the bother.
samhay
Rob - while you're around. I assume you do a toner transfer onto your enclosures before you etch. What kind of paper do you use (yes I am that far behind schedule - haven't started populating the board yet either)?
hi sam, i use photo glossy...just peel it off as it cools... ;)
samhay
knutolai
Quote from: ~arph on August 14, 2013, 02:13:19 PM
Layout I used: https://dl.dropboxusercontent.com/u/1849818/published_images/perf1.png
PLEASE NOTE: There is an error in the layout, don't use it. It is just for reference.
Cant wait to build this! Can we expect a updated layout at some point?  :icon_biggrin:
~arph
I certainly hope so  ;D I need to put it on my list. Because as usual I continue with new projects at full pace.
thofmann
Not really a pedal but I finished it few days ago and people tell me its useful. So why not show it ?
Name: THofmann aka Thomas_H :-)
Pedalname: Purity aka All-In-One
Project Documentation (incl. schematic etc.): http://diy.thcustom.com/?wpdmact=process&did=MzEuaG90bGluaw==
Documentation of the power amp: http://diy.thcustom.com/?wpdmact=process&did=MzIuaG90bGluaw==
What it does:
I wanted to have a tool to do high quality recording of effects on one side and a solution to practice to playalongs on the other side.
The all-in-one took 3 prototype PCBs and more than 3 months to get everything as I wanted it to be.
A very nice side development is the 10W power amp that runs on a 9V supply, is very small in its dimensions and sounds really good.
Specifics:
•   tube input preamp
•   Input gain control
•   FX Loop
•   Wet/Dry Mixer (Its a panner actualy, so you can have 100% wet only)
•   aux in and aux volume control (connect your favourite mp3 player)
•   buffered amp out with volume control (selectable Mix or FX-loop only)
•   wide range single knob tone control.
•   Frequency correction withSpeaker saturation control (can be bypassed)
•   recording out volume control
•   Mic-a Mic-b and line-level output for the recording Signal
•   symmetric line out for XLR connection (DI-Out)
•   headphone amp
•   power amp 10W
for a better understanding here is a schematic with building blocks and signal paths:
and some pictures of the actual build:
Outside:
From the back:
Inside:
What is what:
And a short demo of the tonecontrol and filtering abilities:  https://soundcloud.com/th-custom-effects/all-in-one-recording-mixing
Stereo simulation demo: https://soundcloud.com/th-custom-effects/headphone-amp-stereo
DIY-PCBs and projects:
~arph
tca
I like the power amp idea! Using two tda2003 one for voltage doubling and another for audio.
samhay
liagasg
Guess we've just lost the chance of getting any prize after that build!
Warlord Custom
seedlings
Perrow, sweet build, warm fuzzy tones, great graphics!  :D
TH- I found one glaring omission from your circuit:
Otherwise, it's incredible!!!
CHAD
thofmann
Quote from: seedlings on August 29, 2013, 12:28:32 PM
CHAD
Damn, now you everyone knows that i do kitchen sinks for a living!  :icon_mrgreen:
Govmnt_Lacky
#496
Are silkscreen layouts all that is required for submissions?
I was under the impression that layouts had to be COMPLETE in order for "spirit of DIY" sharing.
I know I wouldn't mind building this DIY style. MAybe post or share the Gerbers  ;D
Am I wrong? Judges  ???
I think you're right Greg. Obviously it's up to the judges but there's a couple of entries that seem to have "required elements" missing.
@thofmann amazing build, love the power amp.
thofmann
You are probably right. I missed the "...and layout" required passage in the contest rules.
Out of the four circuits I used, three are absolutely unique and I did not bother thinking about single sided layouts as there was no way to get the required packaging density.
The Valv-e-tizer has a single sided layout in its V1.1 build document which is freely available.
I am contrary to the "spirit of DIY" saying as you could do your own layout from the schematic and add another level of DIY on top  ; :o
But let me tell you what I think:
First I will leave it to the judges to decide how the rules should be applied.
Second I was really thinking about the "sharing gerbers" idea that was mentioned.
I could agree to put them on for a limited time (lets say 1 month). It would be the 10x10 panel containing the all-in-one board, the power amp and another board that was a fail.
What do you say?
Thomas
midwayfair
