Enclosure grounding spring
Started by Valoosj, May 24, 2013, 03:16:16 PM
Valoosj
Does anybody know where I might find these springs that ground the enclosure, as seen on this pcb?
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
AdamM
looks like a battery contact spring to me
Looks like a battery contact spring to me, too.
armdnrdy
I use this type of grounding lug attached to the enclosure bottom plate screw.
http://www.smallbearelec.com/servlet/Detail?no=803
Valoosj
Thanks. This helped me search for them. Now to find a shop where they sell them in quantities <1000  :icon_rolleyes:
Jdansti
The ground lugs that armdnrdy suggested would provide the most positive connection. If you still want a spring, and you don't care about looks, take a 3-4 inch piece of stripped 18 or 20-ga solid copper wire and wrap it around a pencil or Sharpie to make your own spring. Play with the spacing of the wraps. I've successfully done this with a homemade spring soldered 360 deg around its base to the ground plane. The other end of the spring contacted the enclosure's lid.
