tagboard earthquaker hummingbird tremelo
Started by peterg, May 28, 2013, 09:02:50 PM
peterg
I built the above mentioned pedal and don't hear the effect. The volume pot works but nothing else. The changes I made were grounding the mode switch to the outjack not to the baord. I couldn't find any 2n2646 trans so am using a 2n6027. I've tried all pin variations. Any suggestions why there is no effect?
midwayfair
Chugs
The 2N6027 is not a straight substitute for the 2n2646. It will not work without modifications to the circuit.
There are suggestions for modifications to make a 2N6027 work with the circuit at FSB.
abenfVA
You don't happen to have a schematic, do you?
peterg
Thanks Guys
Chugs - what is FSB? I'll look it up. Hopefully I can salvage the board.
AbenfVA - I couldn't find a scheme just the tagboard vero layout. I found a Vox Repeater scheme which the hummingbird is based on but there appear to be extensive mods.
moosapotamus
My SKIPPY pedal is a modified VRP, but you can find details about replacing the 2N2646 with a 2N6027 in the documentation...
http://www.diystompboxes.com/smfforum/index.php?topic=102557.0
~ Charlie
moosapotamus.net
peterg
Thanks Charlie
I found the schematic and am wworking withh it. I wish I had found it earlier! It looks like a great circuit.
peterg
Charlie
I added the R12 as per your mod for the 2n6027 but still am not getting oscillation. Does R9's value make thaat much differnce? Currently I have a 470r resistor.
moosapotamus
Yes, the value of R9 will make a difference. Try combining a couple of resistors in series to add up to 2K if you can. Then tweak the trim pot to dial in the oscillation at both extremes of the speed pot.
~ Charlie
moosapotamus.net
Electron Tornado
"Corn meal, gun powder, ham hocks, and guitar strings"
Who is John Galt?
peterg
Thanks Charlie. I'll give it a try.
Electron T - thanks for the info on the eletrochop.
peterg
Charlie - R9 was the issue. Sounds great now. Thanks for your help.
moosapotamus
moosapotamus.net
