How can i use my tonebender mk 2 ( pnp germ ) with my "standard" power supply
Started by JebemMajke, May 29, 2013, 09:53:40 AM
JebemMajke
How can i use my tonebender mk 2 ( pnp germ ) with my "standard" power supply, negative ground one? What do i need to make in order for that to work?
Arcane Analog
If it is wired as per standard wiring schemes it should work just fine as is.
JebemMajke
You mean connect + to the ground and - to power? But wouldn't that cause problems when interacting with other pedals connected to that power supply?
lowbrow
You would need to build in a charge pump circuit to generate -9 volts for your power rail. It's a simple one IC chip and two electrolytic capacitor circuit. Many people recommend the Maxx 1044 chip, but I prefer a 7660SCL myself. There are threads here that talk about it, but you can also look here:
http://tagboardeffects.blogspot.com/2012/05/negative-voltage-inverter.html
JebemMajke
Arcane Analog
Quote from: JebemMajke on May 29, 2013, 12:58:28 PM
Yes. You do not need a charge pump at all to use a standard supply. Wire it up as a standard PNP MK2. You power supply will work just fine as is. The only time you need a charge pump is to daisy chain the effect with other pedals that have the standard negative ground. Just use this wiring diagram.
http://www.generalguitargadgets.com/pdf/ggg_sw_3pdt_tb_pnp_dcj_gi.pdf
pinkjimiphoton
yah 7660 is the same.
you DO need a charge pump if you wanna daisy chain the pedals, if i'm reading this right.
Slava Ukraini!
~Jack Darr
Jederino
Soooooo, would the above diagram Fromm GGG also apply to the Fuzz Face I built from GGG?  Mine is the boutique 60's ver., PNP, and negative grounded (although currently not working, so I am debugging it).
pinkjimiphoton
yah, same deal. you can either put one in each pedal, or put one in a box with a couple positve ground outlets, but make sure they are insulated from the case and/or npn pedals or it'll short everything out.
i've heard you can run pnp's backwards with no issues from some people, but haven't tried it.
Slava Ukraini!
~Jack Darr
JebemMajke
I can find  7660 SCPA, no SCL in my area. Will that be an issue?
pinkjimiphoton
Slava Ukraini!
~Jack Darr
JebemMajke
I can;t seem to find any 7660scl datasheet. I've found 7660scpa but no scl.
Arcane Analog
Quote from: JebemMajke on May 29, 2013, 09:53:40 AM
The original question simply asked how you implement a standard power supply with a positive ground MK2. The answer is wire it as per usual - nothing extra or different is required.
Daisy chaining PNP and NPN effects is an entirely different question.
Arcane Analog
Quote from: JebemMajke on May 29, 2013, 06:17:02 PM
I think you can buy the 7660SCPA or equivalents from Mouser for less than the Max1044.
lowbrow
My bad, I got those trailing letters wrong. The important thing is it must have the S after the numbers. What you found will work great. And yes, the pin out is the same ad the 1044.
