Dead Small Clone Chorus
Started by veirum, July 10, 2013, 03:06:20 AM
veirum
Hi
I have a dead small clone. There is sound when it is not engaged but it mutes everything when engaged. It is running on battery and diode turn on and of accordingly. Any suggestions what might could be the problem here?
" I will say no more "
veirum
Fixed it. It was a snapped wire at a sodder point. The yellow wire was snapped down at the connector at the 3dpt switch. So everything is fine. Can someone help me regarding mods for this pedal? A depth knob instead of switch and a blend knob mod would be nice.
best
Jeppe
pakrat
You might try looking at the tonepad schematic to add the depth pot. www.tonepad.com
veirum
Thanks. As far i can see it is based on their own print layout is that right? If so can anyone maybe quickly translate and tell which resistors and their number on the print need to remove and where i insert the knob.
if you go here:
Quotehttp://music-electronics-forum.com/t5746/
mark hammer says where and what, with regards to this circuit, and its mods:
Quotehttp://www.tonepad.com/getFile.asp?id=97
