Very short delay circuit (from 0 up to 50 ms)
Started by HeaD, July 11, 2013, 05:04:45 AM
1mS is one foot of air. Move one mike one foot. Or less, for sub-mS adjustment.
There is a commercial box for re-phasing microphones. Not cheap, but no DIY alternative is attractive.
For low-fi: put signal to a small speaker, through a hose, to a mike. Adjust hose length. Speaker, mike, and hose resonances and flaws make this pretty nasty, but Cooper(?) TimeCube was offered commercially.
toneman
I think there was an old old Audio Amateur Magazine article about making a "delay" out of 1/4in plastic tubing  ???
I remember I had a photocopy of it long ago.   :icon_confused:
But, I doubt I could find it now....  :icon_redface:
:icon_cool:
mistahead
I just want someone to post a basic "capacitor bucket" type cicuit to do basically this.
I'm not good enough to (re)design anything like it but wan't to see how hard I can push a design like that (sideways).
StephenGiles
"I'm looking for a simple circuit that provides a very short delay to a line signal"
Do you mean "line" level, which is considerably higher than instrument level?
What do you need this short delayed signal for?
Fender3D
#24
Quote from: Fender3D on July 11, 2013, 12:36:28 PM
@Mark
when raising clock signal level attenuation is worse than clock current issue...
ie. MN3007 @1.6MHz is 10-12 dB less than @100KHz with or without clock buffers...
hmmm maybe I exaggerated a little...  :icon_redface:
Quote from: Mark Hammer on July 11, 2013, 02:09:36 PM
That's an interesting piece of info.  I never knew that.  Do you have any sense of what the critical point is with respect to where such attenuation becomes more apparent?  For example, would a clock rate of 300khz only lose you 1.3db, or whatever?
Quote from: Thomeeque on August 28, 2011, 06:05:56 PM
(click pic for hires)
I knew Tomas did a good job...  :icon_mrgreen:
Btw
just breadboarded an MN3007 with ADA flanger's VCO.
I had more or less the same results as Tomas
Basically:
-1dB from 30KHz to 350KHz
-2dB @ 460KHz
-3dB @ 600KHz
-4dB @ 760KHz
-5dB @ 900KHz
-6dB @ 1240KHz
-6.8dB @ 5500KHz (yep 5.5MHz!!)
signal 250Hz, power supply 12.6V
puretube
Quote from: HeaD on July 11, 2013, 05:04:45 AM
Hey everyone,
I'm looking for a simple circuit that provides a very short delay to a line signal (from 0 up to 50 ms). I need to output the delayed signal only.
Is there an easy way to achieve this goal? Thanks!
IF you have both signals *electrically",
the SPIN FV-1 is the best HiFi way...
johngreene
Quote from: Fender3D on July 15, 2013, 10:11:03 AM
@Mark
Btw
Basically:
-2dB @ 460KHz
-3dB @ 600KHz
-4dB @ 760KHz
-5dB @ 900KHz
-6dB @ 1240KHz
I've noticed that above a certain clock rate (1.5 MHz?) the signal just blows right through the BBD chip, it no longer changes the delay.
