forgot to ground pots... does it matter? (Rebote 2.5)
Started by maurice, July 12, 2013, 09:01:17 AM
maurice
I've just completed the Rebote Delay 2.5 (www.diy-layout.com/44). It's a great project!
Seems to work fine in the enclosure but I just realised I forgot to attach ground to lugs 1 of both level and repeat pots.
Would this cause problems or issues with sound quality? Should I open it back up and ground them?
midwayfair
Your repeats will probably be out of control (never just one repeat, for instance), and you will have hardly any control over the level.
Unless somehow you've boxed it up and it's working right? :/
pinkjimiphoton
Slava Ukraini!
~Jack Darr
Liquitone
If you forgot something important as ground-connections you shouldn't wonder if it may or may not cause problems, but simply fix it right away.
pinkjimiphoton
an ungrounded pot is nothing but a varable resistance. for some things, that's fine, for others, not so much... like, gain controls, some tone controls etc... but if you need to attenuate/earth signal, it's a must.  ;D
Slava Ukraini!
~Jack Darr
