12v L7809
Started by hazefuzz, July 13, 2013, 01:37:42 AM
hazefuzz
I recently bought a new pedal,
It's came with 12vdc power supply (1000mA) but on the pcb there is voltage regulator (L7809)
http://www.datasheetcatalog.com/datasheets_pdf/L/7/8/0/L7809.shtml
if I understand correctly It's 12v to 9v ........  ??? :-\
so why they just didnt use 9v power supply or battery like any other stompbox
I'm french, sorry for mistakes
WaveshapeIllusions
I would assume that they want that 9V regulated. Regulators drop some voltage, so that difference of 3V is needed to do its job. The supply is most likely unregulated, so I guess they found it simpler to tell people to get a higher supply rather than specify a regulated one.
What pedal is it?
mth5044
Perhaps some of the circuit is powered at 12v and some at 9? Idk
cortezthekiller
I would think that if the pedal uses a 1 amp power adaptor that batteries would be useless and common single-pedal adaptors wouldn't hold up?
Digital Larry
You can free yourself (to a certain extent) from worries about ripple (hum-causing) from the wall wart by doing this.  Get a cheap wall wart then add a (fairly) cheap voltage regulator on board.
Digital Larry
mistahead
Its a digital pedal I'll wager.
I've seem this commonly used to ensure a "perfectly regulated and filtered X volts" to a couple of digital multi's and the such.
