Firefly amp Running off charge pump (555 SMPS) . HELP!
Started by thedoc115, July 21, 2013, 06:06:08 PM
thedoc115
I've made the 555 smps that Frequencycentral designed and used it to power a 12au7 wired like the output of a firefly amp and I'm getting sound but its super quiet.
I use this output transformer http://www.ampmaker.com/store/4W-push-pull-output-transformer.html
any help is appreciated.
psychedelicfish
Voltages? Links to schematics? Pictures? We know almost nothing about your problem from what you've told us, so we won't be able to help unless you give us some more information
If at first you don't succeed... use bigger transistors!
thedoc115
#2
this is the schematic. http://ax84.com/media/ax84_m276.gif
I made the power amp which is every thing past R12
as for voltage I've tried every thing from 100-280v
and its drawing about 10ma.
psychedelicfish
I take it you included R12? The power amp doesn't provide much voltage gain, so you really need the preamp to provide the power amp with enough signal to make good use of. You should either include the V2 sectoin, or you could try replacing the 12AU7 with a 12AT7, which has far more voltage gain, but can still drive the output transformer
thedoc115
#4
Yes R12 was included I tried it with a 12AT7 and it was a little bit louder but not much ( my guitar strings are louder).
I tried giving the the tube more signal by using a tube screamer and it made it louder but not by much.
I have a smokey amp and its louder than this at the moment.
*edit* I'll make the preamp and see if its any louder.
psychedelicfish
The preamp will give you more volume than the TS, which can do about 1V p-p, while the preamp will give you far more
You need over 10 Volts of signal there to get the full power output.
Guitar signals are more like 0.1 Volts.
You need a LOT of gain in front. More than most "boost pedals".
Really, the best thing at this point is to build the V2 stages. That WILL give full output from guitar-type sources.
Alternatively: derive a 50V power supply and use two JFETs or a hi-voltage opamp chip to get gain over 100. However since you *have* a 250V supply, and heater power, and the V2 stages use a small fraction of the V3 stage, another bottle is probably the best path.
That V1 stage looks over-the-top to me. Not a bad idea, but not as essential as the V2 stages.
thedoc115
I think I'll build the v2 stage and see if its any louder.
As for the SMPS does the maximum current draw increase if the wallwart is say 3A rather than 1A.
Striker Amplification
CHECK all of your cathode resistors, if ANY of the preamp valves are in fact overbiased you will get a smaller negative electron flow from the cathode to the anode/plate, causing the tube to amplify less, this goes for the power section as well.
Builds:Plexi superlead mkll 100,plexi superlead mkll 50, 59 plexi, 59 4x10 bassman, marshall bass and PA head 100, JTM45, modded JTM45-lead,JCM800 lead 50.
Scruffie
I did what you're doing with a MAX1771 power supply with the 2nd preamp tube, worked great!
Check the SuperFly thread for the schematic/PCB/info.
thedoc115
Quote from: Scruffie on July 22, 2013, 06:21:22 PM
What kind of volume level did you get out of your amp.
Scruffie
Quote from: thedoc115 on July 23, 2013, 02:54:52 AM
Bedroom levels, 1/2 - 1watt I guess.
thedoc115
Should have this finished by the weekend, I'm just waiting on some small parts.  :icon_mrgreen:
DougH
That question makes no sense without the context of the speaker you are using.
Scruffie
Quote from: DougH on July 23, 2013, 09:04:52 AM
Indeed, I did try it through a futurlec 3w rectangular speaker, that was fun and toy sounding. Still had a decent bit of volume on tap though if I recall.
thedoc115
#15
Ok, I've made the V2 stages but its still really quiet.  ??? what should I check.
Checked the wall wart and only seems to put out 11.88v (the heaters are also only getting 11.88v) , should that matter?  ???
psychedelicfish
How much current can your wall wart supply? The heaters of 12A*7s will pull 150mA at 12.6V, and 300mA at 6.3, so your wall wart will need to be able to do 300mA and whatever the rest of the circuit takes, but you generally should be able to supply at least twice the current you need, because the voltage tends to sag when you pull close to the max current. Check voltages have you got on the valves. Check and double check the wiring. Check the AC voltage coming out of the V2 stage when you strum hard into it. What speaker are you using? What valves are you using?
thedoc115
#17
Quote from: psychedelicfish on July 28, 2013, 01:05:24 AM
My wall wart can supply 3A, the speaker is an 6in 8ohm 10w and the V2 valve is a 12ax7, V3 is a 12au7.
I think I'll try some other tubes just in case.
The plates of V2 are getting about 140v
The output in Vac from V2b is about 20v with a good strum
I actually used this preamp http://www.muzique.com/news/images/Epi1.gif
everything thing up to C2.
thedoc115
#18
Tried some different tubes but still no difference  ???
What am I doing wrong ???
It would appear that the tubes are drawing 280ma (high voltage) now I'm really confused  :icon_question: :icon_eek:
on the output transformer (output jack) I'm only getting about 1-2Vac.
Could my output transformer be bad. :icon_exclaim:
thedoc115
ITS ALIVE!!!!
I'm the biggest arse in human history...
R13 on the firefly schematic should be 440 ohms not 470k :icon_rolleyes: :icon_lol:
Case closed...
it works and is very loud through a 1x12 cabinet.
pictures to follow soon....
:icon_mrgreen: :icon_mrgreen: :icon_mrgreen: :icon_mrgreen: :icon_mrgreen:
