Quick question about an Ebay Product before purchasing it
Started by Ofek Deitch, July 23, 2013, 02:52:28 AM
Ofek Deitch
Hi guys :)
I'm tired of wiring leds, cuz it always takes me a lot of time, so I decided to buy LEDs that are already wired and put into their bezel.
I found this (link below) and my question is will it work with a normal 9V power supply? (Ignore the price. I found a cheaper place).
http://www.ebay.com/itm/290950085469?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Thanks,
Ofek
psychedelicfish
It says they're wired for 12V, so you should be fine with 9V, but be aware that it will be a little dimmer.
If at first you don't succeed... use bigger transistors!
They are probably just LEDs that have a resistor already wired in series with them, in the photo you can see a bulge under the heatshrink that looks like a resistor. The resistor will be chosen to give a certain brightness using a 12 volt supply, so they should work at 9 volts but won't be as bright. If they're running at maximum brightness at 12 volts then they will probably still be bright enough at 9 volts, we normally run our LEDs at nowhere near full brightness.
Ofek Deitch
There resistor is 470r, so I guess no problem.
tubegeek
reverberation66
I never use led's, battery suck...if you can't tell if the effect is on or not you're doing something wrong.
mistahead
Quote from: reverberation66 on July 23, 2013, 10:03:55 PM
Drinking, going deaf, being cheap on monitors, playing rythm with a typical lead, and trusting the sound guy up back...
Yep - I'm doing everything wrong aye.
