Clean tone but no distortion(HELP)
Started by Otsismi, July 28, 2013, 10:35:20 PM
Otsismi
I recently bread boarded the dod 250 IC circuit. When plugging into my amp I get a relatively boosted but clean signal from the circuit but no distortion or overdrive. The gain pot does nothing when turning. Can anyone give me some suggestions on why I'm not clipping?
mistahead
Did you check:
http://www.diystompboxes.com/smfforum/index.php?topic=79242.0
If not perhaps check out the debugging thread, voltages etc if you've got good electronics methodology/background already...
Otsismi
Why does changing the capacitor cause it to start distorting?
mth5044
There seems to be some confusion with your layout.
The bus terminals are long strips, so the two red strips and the two blue strips are four long connections. You have those two long orange jumpers connecting... the same things. The large blue resistor isn't connected to anything. Your IC has no power going to it. The resistor on the bottom left next to the black probe isn't connected to anything. I'm very confused by your layout!
Otsismi
I'm confused about your assessment because I got it working last night.
mistahead
Can you take another pic for us?
Looking at what was said RE breadboarding, it is looking strange...
You could have a working distortion circuit that sounds great, but that doesn't mean its exactly correct./
Quote from: mth5044 on July 29, 2013, 05:00:44 PM
It's a 741, so power comes in on pin 7.  But you're right about the resistors.  The photo looks like it's disconnected from any power supply.  That large blue (100 ohm) resistor top-right should be connected to the 9V source.  This schematic at Beavis might help folks...
Otsismi
Otsismi
I followed the beavis schematic religously
mth5044
It seems as though things have drastically changed since your first picture. You've added power, LED's and a few other things. It's a little hard to follow as it seems there are jumpers in strange places. What are those large orange along the power rails jumpers doing?
Otsismi
They connect the rails. I found that the rails are connected half and half
Otsismi
I had power the first time it just wasn't connected in the picture. When I switched a capacitor it started to work. I added the diodes because I like the crunch
mistahead
Quote from: Otsismi on July 30, 2013, 07:39:30 PM
Half and half aye... I may need to crack out my MMeter and do some continuity checking tonight, I though my rails (where you've jumpered using long orange) were grouped in fours with no continuity between groups, but I may have done this by just testing continuity within one group, and then down at the other end of the rail entirely, without checking anything in between.
Good to hear you've got a circuit you like mate!
Goodrat
Yeah, those rails drove me crazy one time until I discovered they were split in the middle.
BTW, if you get it working and it squeals, remove the metal bottom it is mounted on.
rails: should only need  a tiny jumper between groups of five.  in the middle.
experiment with different diodes too...and switch between.
