9V battery getting warm/hot
Started by mordechai, July 28, 2013, 11:49:07 PM
mordechai
I just tried wiring up an effect via battery power.  The effect isn't working/powering up, and the battery is getting uncharacteristically warm/hot.  I know I am doing something wrong; anybody have an idea what might be causing this?
mistahead
Short circuit, too little resistance between the + and - on your battery (probably near zero R short).
psychedelicfish
If at first you don't succeed... use bigger transistors!
Quote from: mistahead on July 28, 2013, 11:50:37 PM
Yep, definitely a short somewhere.  Disconnect fast and check your wiring and board.
