Help!
Started by Blueman95, July 29, 2013, 08:00:49 PM
Blueman95
Hi everyone,
Hoping somebody out there has had this problem before and can help out
I am totally new to DIY pedals and have just (nearly!) finished my first silicon fuzz pedal. The problem I'm having is that the pedal works when out of the enclosure but when connected to the casing I am getting no sound whatsoever. Is this a common problem for first time builders? Can this be fixed without starting again from scratch? If so, how do i go about it? Any help would be greatly appreciated.
Cheers
Danny
haveyouseenhim
What kind of power jack are you using?
Blueman95
Using a boss 9v ac adaptor.
Cheers
haveyouseenhim
I mean the jack. Like the part that is mounted to the enclosure. Is it metal or plastic?
Blueman95
Sorry, it's a metal one. It's also a stereo jack if that makes any difference? I do have a couple of spare plastic jacks to hand, would it be worth changing it for a plastic one?
LucifersTrip
need plastic (unless your enclosure in non-conductive) or you'll short it out
http://www.taydaelectronics.com/dc-power-jack-2-1mm-enclosed-frame-with-switch.html
always think outside the box
haveyouseenhim
That's your problem. The metal jack is shorting the power supply. The enclosure is grounded by the in and out jacks and the positive 9 volts is on the barrel of the plug touching the enclosure. Try an insulated power jack like this.
http://www.taydaelectronics.com/hardware/dc-power/dc-power-jack-2-1mm-enclosed-frame-with-switch.html
haveyouseenhim
Quote from: LucifersTrip on July 29, 2013, 08:42:30 PM
Hey man, back off!!! I need to feel like I actually have knowledge around here :icon_razz: :icon_razz: :icon_razz:
Blueman95
Thanks. I've actually got one of those. I'll try that one instead and let you know if it works. Appreciate the help.
digi2t
That was my very first troubleshoot on my first build, a Gristleizer. Used a metal jack. Luckily, the spark I saw when I plugged it in gave it away.
Ahhh... the good ole days.  :icon_lol:
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
mth5044
The Gristleizer was your first build.. and that was your only problem? Impressive.
tubegeek
Quote from: mth5044 on July 29, 2013, 11:25:07 PM
He said "first," not "only."
-j
