EQ + (Engineer's Thumb x2+) = multiband comp.?
Started by MrStab, August 01, 2013, 11:09:22 PM
samhay
I don't think you have killed your op-amp. My guess is that there is either:
(1).  a short somewhere or a small resitor to ground rather than Vref. This may explain whay Vref is 1.7V - this is not a good thing, and what I would focus on first.
(2).  the LPF is set way lower than it should be, so it is barely passing any signal. This could happen if you R6 and/or R7 are >>1k of if the pot is >>100k or if the caps are not 10n and 22n. Does the HP signal sound essentlailly identical to the dry signal out of U1A?
samhay
After looking at Vallhagen's new PINKING 3 band distortion (http://www.diystompboxes.com/smfforum/index.php?topic=102861.msg929656#msg929656), I realised that I had not added any phase compensation to this design.
This is not a trivial task if you want to sweep the crossover frequency, and should not be a problem if we are using a subtractive method to generate our HPF. However, if it all starts working and you get a weird comb filter effect, then I guess we may have to have  a think about the crossover design.
