Compressor Problems
Started by mattlee0037, August 06, 2013, 11:05:25 PM
mattlee0037
I used the layout from here http://www.sabrotone.com/?p=1331
It works kind of. The problems: to get unity volume I have to have the pot set up at about 90% clockwise and the LED doesn't currently light up. This might possibly be due to my 10k limiting resistor (only one I had on hand and too impatient to wait for a 4.7k) or something else I'm not sure. Another strange anomaly is that when turned fully counterclockwise the volume pot measures about 9.7k resistance, but the compression pot (also a 10k audio pot) measures about 3.3k so I'm not sure if this was because it was in circuit or what?
Anyways, thoughts are welcome, I will try to post pictures and voltages tomorrow.
GibsonGM
Yup, gonna need the voltages ;o)  Many things could be wrong; but the good news is, it is probably only 1 or 2 errors causing the malfunction!  You just have to track it (them) down....debugging......read the thread at the top of the forum about that.    Take your time, and you'll find the trouble!
samhay
The compression pot (10k) is parallel to a 5.1k R15, so at max you should have 10k||5.1k = 3.4k, so that is not the problem.
What LED? I don't see a 4.7k resistor in that layout.
I would not expect the LEDs in the feeback loop of the op-amp to light up unless you put a lot of signal through it.
mattlee0037
Sorry I meant the status LED. I always forget to be clear about that! I promise I will have pictures and voltages tomorrow!:)
mattlee0037
So I didn't have much time to check voltages so I will be more thorough later, but D1 had about 8.8v D2 and D3 had about 0
Pin 1 of IC had 1.4
Pin 2 had 4.8
I think I saw a solder bridge, but I'm not sure if it would cause all those voltage problems! I'll try cleaning it up soon to see what happens.
mattlee0037
Ok so here are my voltages
Just a note that I fixed the status LED, but now the volume control has no effect :(
DC jack: 9.54 (good start haha)
Status LED anode is getting 1.86 (and lighting up)
D1 cathode is 8.91
Q1 has 0 on G,S, and D.... hmmm I don't think that's supposed to be like that...
D2 and D3 cathodes have 0 :(
IC is 1- 3.63
2- 4.84
3- 2.40
4- 0
5- 8.84
6- 4.84
7- 4.84
8- 2.39
D5 and D4 all points are about 4.85
So this is very befuddling. Maybe some bad contact with sockets or something? I'm not exactly sure. Thoughts?
If the op amp is being used in a normal way i'd have expected most pins to be around 4.5 v except pin 8 which should be around the same as your 9v source and pin 4 which goes to ground so 0volts
IF?
google up lovesqueeze voltages you just might find something.
Not help for your problem, per se, but I think you're counting your chip pins in the wrong order.  You start at the dot (or "bite mark") and go anti-clockwise:
Otherwise your pin 8 (2.39V) is completely wrong - it should be close to your 9V supply.  Which is what you have on your pin 5.  I think you've counted down one side, then down the other (and thereby reversed 5, 6, 7, 8).
mattlee0037
 ;D I did count them wrong.
Real voltages are
IC is 1- 3.63
2- 4.84
3- 2.40
4- 0
5- 2.39
6- 4.84
7- 4.84
8- 8.84
I'm going to try and see where the voltages are dropping from the input  9.54 to the diodes 0 tomorrow.
> I used the layout
Layouts are good for building.
Schematics are very-very-very helpful when *debugging*.
It is a kindness, when asking for help, to point to the schematic.
http://2.bp.blogspot.com/-oBz_XMAZSd8/T-jvPvJdWTI/AAAAAAAABk0/pF9SOGcl8PI/s1600/ROTH.png
Yes, at idle all pins of Q1 are zero. Also D2 D3.
All pins of opamp should be at +9V, zero V, or +4.9V.... except depending on your meter, pins 3 and 5 will read 10% low (or lower). Hmmmmm.... you report 3 and 5 way low. What kind of meter?
mattlee0037
I use a cheapie digital multimeter, although I've A/Bed the results with a very very expensive multimeter, and they're normally the exact same. I rechecked just to be sure and I got about 2.40 again for pins 3 and 5
Short FET drain-source. That should be LOUD. Is it?
If so, but not when the FET alone is there, re-re-examine FET type and pin-out.
mattlee0037
No it's at about unity volume and the volume will not adjust when rotating the potentiometer. And I just looked at the type and it's a bj26 or bj28 2n5457 which I couldn't find any datasheets for so I assume a regular pinout? Potentiometer resistance does still vary as the pot is rotated.
mattlee0037
Edit: it get's a *slight* volume boost when engaged.
mattlee0037
Second Edit: I'm an idiot :facepalm: I hooked up the LED to the circuit wrong because the PCB is a tad odd, so it currently lights when the effect is off, so there is a *slight* volume drop when engaged.
Pojo
I'm wondering about the bias supply voltage....what measurement do you get at the positive lead of C6?
assuming and pinouts don't go together.
the 2N5457 is the same pinout as the j201, but that's off the top of my head ......
" I will say no more "
mattlee0037
To Pojo, 4.73V was measure at the positive lead of C6
And to duck arse, are you suggesting I sub in a j201 for it to see how that goes?
sub a 2N5457? NEVER! j201 is a different beast altogether.
no, I was just pointing out their pinouts is all.
