MXR Microamp clone with Led Popping (from GGG)
Started by JPGraphX, August 20, 2013, 01:03:55 PM
The reason I ask is because i once boxed up a son of screamer and the enclosure had not been grounded and it wasnt until i grounded the enclosure the pops went away.
JPGraphX
May be it looks suspect but this is the third time I resolder everything..
JPGraphX
I took Dc measurement again, nothing at input, nothing at output, I have a little bit dc from amp, like 8-10 mv, but this is my cheap amp, and I have the same problem from my good one, So I dont think it is coming from amp
JPGraphX
So: my pedal works perfect, LED isnt doing the pop, and I have tested all my parts, no DC from inout/output.. Damn!
So it works perfect with no pop outside the box?
JPGraphX
No, I have a pop outside the box, I meant, everything works well except I always get a pop whatever I do.
pappasmurfsharem
Quote from: JPGraphX on August 22, 2013, 05:43:01 PM
Someone stated earlier try without the switch.
So hyou will take thes and touch them together for the in out wires and jacks. if you get a pop then you know it's the switch.
JPGraphX
I'm not sure how to rewire everything? Do I have to remove everything on the switch? Please give me some hints
JPGraphX
mistahead
Think about how the switch works - it connects lugs inside it.
Just paperclip the appropriate lugs outside it.
looking at the circuit, R1 being the input pulldown is rather a high value at 22M. perhaps if you reduce this resistor to 1M thereabouts.
all facts now attract a 25% 137% reality tariff.
"Did I say that?"
pappasmurfsharem
Quote from: duck_arse on August 24, 2013, 01:47:38 PM
I think I did a 10M in mine with no issues, not that I thought there would be one of course.
JPGraphX
pappasmurfsharem
