Volume Pot Help.. ROSS
Started by HelpingFriendly, August 29, 2013, 08:55:05 PM
HelpingFriendly
 I was wondering if someone could be so kind to either sell me a replacement Volume pot for my vintage Ross Comp. or send me in the right direction of where to get one. I want to get the exact same (specs) as the original. The original one broke. I know it's 50K audio taper but I need the right size so I can solder it in with no issues. I have an original (tawain) Ross. I really appreciate any help you can give. Thanks
pappasmurfsharem
I would imagine it's either a 24MM or a 16MM take pic of it.
HelpingFriendly
Disregard red and yellow circles
pappasmurfsharem
Hmm that's a strange one, I don't that one on alphas site. I see some reverse pinned 16mm pots http://www.alphapotentiometers.net/html/16mm_pot_3.html
but the shaft doesn't look right.
I would just buy a Solder Lug Long shaft pot and use wire to put it through the PCB holes.
No idea what type of pot that is
HelpingFriendly
it says 443F 50KB on the side of it.. Someone please help me!!!  :icon_cry:
GGBB
I can't really tell from the picture, but if the only thing wrong with it is that the shaft has come out, it might be repairable.  Check out http://www.geofex.com/article_folders/potsecrets/potscret.htm - pictures there should give you some ideas.
zombiwoof
Did you measure it?.  Is it 16mm or 24mm?.  It looks like a 90 degree angled pc mount pot with the two mounting brackets (like a "snap-in" pot) that hold it to the board.  Is that a "D" (flatted on one side) shaft?.   Definitely might be hard to find.  One option would be to look on Ebay for a non-working Ross pedal of the same type that you could get parts from, but you might have to save a search and keep looking for some time.
Good Luck,
Al
HelpingFriendly
Quote from: zombiwoof on August 30, 2013, 11:29:55 AM
Good Luck,
Al
Yes you are correct. It is 24mm. I know it will be hard to find with the "D" but is there something similar I can make work?
zombiwoof
#8
Quote from: HelpingFriendly on August 30, 2013, 11:25:43 PM
Good Luck,
Al
If you can find a similar pot with a plain shaft, you can file off material from the top of the shaft to accept the "D" shaft knob.  Look for a 24mm 90 degree angle pc pin pot with the mounting brackets and a straight shaft (not knurled), and file the notch to make your own "D" shaft.  I think it will be difficult even to find a pot with those specs, but maybe they are out there.  Make sure you know if the shaft diameter is 6mm (might be since it appears to be an Asian-made pot) or 1/4".
Al
GGBB
You could also just get regular solder lugs and run jumpers to the board.  The shaft and bushing and how the knob fits will be the tricky part.
