synthy filters for guitar..
Started by deadastronaut, August 30, 2013, 11:59:12 AM
nick d
                         Amended schematic , old-school cut'n'paste using real scissors . Also added control labels and
                          + and - inputs to second half of 13700 . And switched flash on .
                          Yeah , you can max the resonance and play sirens with the LFO , no bother !
nick d
           Oh dear , it really isn't my day , is it ?   + and - inputs , I accidentally swapped them .
            Pin 14 is + , i.e. non-inverting , 13 is - , i.e. inverting .
            Fingers crossed , it's all correct now .
nocentelli
Quote from: nick d on September 26, 2013, 07:28:09 PM
So the connections you've drawn are correct, just the + and - labels are swapped?
nick d
            Yeah , pin 13 goes to 10k to pin 9 , pin 14 is from the 10k that comes from pin 8 .
             Checked against my 12 V schem and the rats nest on the breadboard , which works !
nocentelli
Just logged in to say I layed out this circuit last night and had a quick play this morning and it works fine. I could do with a little more resonance, but I'll have a play with the "feedback" opamp and see if I can get a bit more. I'm going to try it with the envelope detector section from the BJFE snow white autowah, which looks like just drop in there. Thanks, nick d.
cool, look forward to hearing your results... 8)
(waiting on my 13700's..)
nick d
#106
               Got a bit further on with this . Video demo included , you may wish to cover your ears .
                 Two LFO's tried , value of C changed to 47nF . Vr now from a buffer using similar circuit as for filter Vref .
                  - this is definitely an improvement .
                Added buffer/boost to input to counter volume drop . This works a treat , straight lift from the Cliff Schecht
                  design .
                The LFO's definitely need level controls , particularly for fast rates . Not done this yet , I'm thinking a 47k pot
                   if using a 33k resistor , and the bottom end of the pot should be Vr , NOT Gnd ?
nick d
       Cheers Rob !  @ nocentelli , no lack of resonance here , too much if anything !
@nick, sounds really great man..great slow sweep.....that'll be nice with an envelope detect too...awesome. :icon_cool: :icon_cool: :icon_cool:
nick d
                Thanks Rob ! Yeah , that long sweep is mega , with the res well up . I'm looking at envelopes
                 too - either follower or triggered . There's a fairly simple ( ! ) on  MFOS in the Noise Toaster
                 project , might be good with a momentary stomp to fire a one-off Attack/Release sweep .
nocentelli
I'll check over mine carefully this afternoon, problem just user error.
nick d
             With my values ( 47k pot + 12k res ) , the resonance increases up to around 90% pot rotation ,
              then oscillation kicks in .  I found two things that kill the resonance while I was wiring up - either
              the bottom end of the resonance pot , OR the 4k7 from IC3 , pin 2 not connected to Vref .
@nick: just listened to the vid again...really nice. 8)
did you get any further with this?.
nick d
    I am in the process of a final build - basically the circuit from the demo with a few minor tweaks , plus an expression pedal jack  .
    Didn't get any further with envelopes - it's an eight-knobber as it is !
   When it's done I'll post pics , clips and schemo . The vero is fairly huge and sprawling , so I won't attempt to draw that up , I'm
   sure someone else will do a neater job !
8 knobs  :icon_eek:
lfo leds?
lfo volumes?.
anyway, cool, look forward to the build demo man... 8)
i now have my 13700's..
nick d
  Two LFO's , each with level and rate pots  and LED , resonance , filter frequency , input boost , output level . The input boost is set-and-forget so could be a trimmer , but it just adds a bit of flexibility . I might add another jack for external CV , so envelopes , sequencer , random etc. could be added later . That's what voltage control as all about !
Strategy
well done! is this HP and LP together like original MS20, or just LP?
Quote from: deadastronaut on November 25, 2013, 12:18:33 PM
very nice... 8)
www.strategymusic.com
www.community-library.net
https://soundcloud.com/strategydickow
https://twitter.com/STRATEGY_PaulD
