synthy filters for guitar..
Started by deadastronaut, August 30, 2013, 11:59:12 AM
ok, for my next trick i shall be breading up the 9v ms20...and then adding lfo. :)
tinker, tinker...
nocentelli
Excellent: Currently got another MS20 on the breadboard in an attempt to get an envelop filter out of it, but please share your LFO findings.
okey dokey..will do.
breaded the ms20 twice with no joy though....hmmmm... ;)
nocentelli
Is it the Escobedo version you can't get to work? I used the Eric Archer schematic -
http://ericarcher.net/devices/diy-lpf/
I used the rail splitter and rail-to-rail opamp specified in the schematic, and initially had some confusion because the 4.5v vref supplied by the rail splitter is labelled as "0v" throughout the schematic. Once I got that sorted, it worked fine. You can omit the mix pot for guitar use, I just connected the 33k/10k junction from the OTA output to vref via a 10k to simulate 100% wet, and left off the dry path from the input->output mixer.
Hi leo, yep its the escobedo. one......its still not having it, i'll attack it again later.....probably pilot error.. ::)
that eric archer one sounds cool,  but i have the bits for the escobedo one...
Haven't got  'darlingtons' and other IC....at the mo, so i'll persevere a little with this for now...
have you got your envelope going yet?..love to hear it.
D'Astro, check out the Cliff Schecht version. single side MS-20
well i think i'll have to go with something other than  a 13700n filter...tried  4  IC's...breaded it 3 times ...no joy..bummer
i never had any joy with these IC's, even when i tried the mutron V a while ago either...so they are either fake or fried....or i am more dumb than i thought.. :)  (quite plausible)
anyway....
nick d
          I built an MS20-type filter using LM13700 in a synth/noise box with dual LFO's a while back , just tried it out with guitar . It actually sounds pretty good IMHO , especially if you like Hawkwind-type stuff . I have posted a clip on Youtube , should be up in a while . A minor complication regarding stomp-box use is that it runs on +/- 12 V , but I'm sure that can easily ( ! ) be sorted . The VCF is based on one from the EFM Wildcat synth , the LFO's are from MFOS , as is the noise generator . Very noisy , very lo-fi , very fun !
^ yep i like old hawkwind stuff...and red shift, tangerine etc...i mess around with reason synths quite a bit too.. :icon_cool:
look  forward to hearing it man.. 8)
ive temporarily gone back to the dual Q&D for now...sounds pretty good..
If you find a way to get the farty distortion down, let us know.
nick d
             Right , I have posted a clip on Youtube of this MS20 box . Can any of you wonderful people tell me in simple words how to link it to here ?
             I've had three tries , all I get is " Invalid Youtube link " . Please , help the Noob !
copy the link at the top of your youtube vid  (url )...not share etc...
then choose youtube from here (top left)
then paste your copied  link between the brackets...
nick d
[yohttp://www.youtube.com/watch?v=gTjcnvy31zI&feature=player_detailpageutube][/youtube]
       If I've got this right , you should see a demo of some MS20 tomfoolery ......
nick d
        Hmmmmmmm.......... nth time lucky ?!?!
nick d
      Ha ! It worked at  last ! Rob , you are a gentleman and a scholar !
      By way of explanation , the other boxes are :-
              Middle - by-pass loop switcher
              Left - BMP type fuzz
              Right - A boost , needed this to make up for a slight loss of volume at min resonance .
             The controls on the filter/LFO/noise box are marked and should be ( ? ) self-explanatory .
             The demo also includes oscillation at resonance and a bit of noise gen sillyness .
nocentelli
Cool vid - which MS20 schematic and which LFO did you use?
nick d
           I downloaded the EFM schematics from a site which I have totally forgotten the name of - the schemos had a lot of errors and missing values , so I had trouble getting it to work properly . The main snag was that the resonance control worked like an off/on switch !  Then recently , I found a synth site called Lushprojects - they do a module " Lushone " , which was practically identical apart from the resonance section . I made the appropriate mods , the end result is what you hear !
           The LFO's are from " MusicFrom Outer Space " -what a great site ! - look at the " Oldies but goodies " section - there is one called " Super-Simple LFO " - I used that but cut the Saw/Ramp bit . The NoiseGen is MFOS , not sure which one .
            If you look at any of these VCF's , the CV is input via a 100K res usually . To use multiple LFO's or other modulation sources like envelopes or exp. redals , just add more 100K's .
          I have not yet tried a 9V version , there is one a few posts back by Cliff Schecht - looks slighty more complex , but a similar idea . It has the bonus of a boost on the input , which would solve the problem I had .
          I think the only issue in using 9V instead of +/- 12 might be a smaller voltage swing from the LFO , giving a milder effect . Possibly reducing the 10K resistor(s) on the 13700 current inputs could fix this ?
          I am going to have a go at a 9V version , with more modulation possibilities - a triggered EG would be cool , perhaps a random LFO as well ? ???
QuoteThe LFO's are from " MusicFrom Outer Space " -what a great site ! - look at the " Oldies but goodies " section
Most of his projects include LFOs, there's a ton of stuff on that site, don't be afraid to adapt some of that simple synth stuff to guitar.
QuoteI have not yet tried a 9V version , there is one a few posts back by Cliff Schecht - looks slighty more complex , but a similar idea.
That version has a nice single sided current source, it's a benefit of Cliff actually being an engineer.
QuoteI think the only issue in using 9V instead of +/- 12 might be a smaller voltage swing from the LFO
+/-12V = 24V. 9V = +/-4.5V. kinda big difference.
QuotePossibly reducing the 10K resistor(s) on the 13700 current inputs could fix this ?
Be careful! Too much current and bye bye OTA
