synthy filters for guitar..
Started by deadastronaut, August 30, 2013, 11:59:12 AM
nick d
Quotehttp://www.diystompboxes.com/smfforum/Themes/diytheme/images/bbc/quote.gif
           I know , max current for13700 is 2mA , so it anybody is not familiar with Ohm's law , learn it NOW !
nick d
          Thanks , Rob !  When I clear up the bench a bit , I'll mess with a 9V version . Not tried the Escebedo version , the resonance section on that looks odd compared to the others - most have an op-amp with diodes  (like a TS ) in that area . Perhaps that's why you had trouble with it . I think I'll try mine as it is re-arranged for single-ended 9V , and tweak it up .
         Assuming it works , I will share my results .
Nice one,  i removed the resonance pot entirely..
i had a thought about having 2 lots of filter caps on each opamp... :icon_idea:
so it can be 4 in total using both opamps....2 each side....
ill give it a go on one opamp to see if it works...
nick d
        I have good news ! My 9V version of the MS20 clone works ! Not put any modulation on yet , just varied the control current to pins 1 + 16 with a pot  .
        The schematic I used is basically the Rene Schmidt version ( RS 20 ) , with  +15 = 9V
        Gnd = Vref
        -15V = GND
        Vref is from a pair of 100k's as a potential divider into an op-amp buffer . The buffer is important , without it , Vref is all over the place
        Lots more work and tweaking to do , but the basic circuit is a runner !
QuoteThe buffer is important , without it , Vref is all over the place
I ran into that problem right away.
cool nice one nick..
i just ordered a couple of 13700's from tayda, ...hopefully these ones will work. :o
then i can try it...AGAIN. :)
nick d
         I usually get mine from Bitsbox , £1.24 at last look . I got 10 last time , heard rumours that they were getting scarce .
ahhh bitsbox..of course, oh well ,  i'll wait.. ::)
just messing around with a crude envelope detector...( different sound to light circuit , no 386)
Quotei just ordered a couple of 13700's from tayda, ...hopefully these ones will work.
Yay! You'll be happy you did. A true VCF with a real current source sounds so super synthy!
nick d
          Got this running with an LFO now , after a lot messing with the control node . The sweep is not as extreme
            as the  +/- 12V version , but that is as expected . At low LFO rates , the effect is very mild on a clean signal
            unless you crank the resonance - sounds OK with some dirt , though !
         Hopefully , I'll post a schematic soon , after a little more twiddling .
Strategy
I'm still dreaming about a "frostwave resonator" workalike - ms20 lp and hp filters in same box!!!...
Strategy
Quote from: garcho on September 25, 2013, 12:11:14 PM
www.strategymusic.com
www.community-library.net
https://soundcloud.com/strategydickow
https://twitter.com/STRATEGY_PaulD
nick d
                                  [/URL][/img]
                                  Did that work ?   ( Using PhotoBucket for the first time )
nick d
nocentelli
nick d
                 Aaaahhhhh .... GOTCHA !
                 Scanners , don't talk to me about scanners.......... ! It's been one of those days , y'know ?
                   Anyway , here's a schematic of what I've got in the breadboard right now . One or two points to note -
                   Separate  V/2 connections for filter and LFO , marked as " Vref " and " Vr " . The op-amp buffer for Vref is essential ,
                      Vr for the LFO probably should be .
                      I didn't use a level control , the LFO is at max output . If needed , it works just like a volume control ( See box at
                        bottom of schem ) .
                      Extra CV inputs can be added at point " X " , via separate resistors - I used 33k , any less and the LFO
                       output seems to " bottom out "  and " thump "
                      I used 100nF for the LFO rate capacitor which gives a long , slow sweep , several seconds a cycle up to around
                       5 Hz - adjust to taste !    Slight thump noticed at high rate .
                       The pot values and tapers are just what was handy , could well be improved on .
                       There is a slight volume loss at low resonance , so a simple boost at the input would be useful .
                        Overall , the sound is similar to the +/- 12 V version , but the modulation level needs to be pretty well
                         maxxed out , though . Sounds good with the resonance well up and fed with some dirt , mind you !
                        I have to say that the control node section looks a right mess , as a result of my semi-random
                          fiddling - that 47k to ground looks WRONG - but if you pull it out , it don't work !
                       Anyway , breadboard it and  see what you can come up with - envelopes could be worth trying .
nick d
               Oh , in my infinite stupidity , I omitted to label the pots - DERRRR !
                  47k Log = Resonance
                  100k Lin ( at bottom )   Frequency
                  100k Lin ( in LFO )     err , LFO rate
                   Also , the 270R 's in the filter were 220R in the original , but I ran out . Probly makes no odds .
nocentelli
Quote from: nick d on September 26, 2013, 02:33:04 PM
Thanks for this! Going to try it out soon. Quick question - All other MS20 schematic I've looked at (not that many tbh) have the control voltage going to pin1 and 16 simultaneously, here the LFO seems to connect via a tiny cap to pin 5 where the resonance feedback also connects - What difference, if any, does this make?
nick d
             Well spotted , Sir ! My boo-boo - pins 1 and 16 SHOULD be connected to the control voltage node , collector of the 3906 .
              The 470pF should connect to the output of the op-amp in the resonance circuit .
              Been looking at filter schems so much my brain has gone cross-eyed !
              Thanks for pointing that out !
nocentelli
No problem, I haven't tried a filter with an opamp for the resonance before, and it's good to kno that it works with that LFO: Thanks again for posting it up.
