Another gig tonight, another pedal not working.. Please help me!
Started by JPGraphX, September 04, 2013, 02:20:56 PM
JPGraphX
Hi guys!
Again, I have a pedal not working Lol. I built a veroboard ts808 and I used it without 3pdt (always on). It was working perfectly. Today, I received my switch so I rewired it and, no sound, on and off. When I switch it on, led is working, I hear some noise (like when the pedal is on) but no guitar signal. Any advice on this?
By the way, tip to tip continuity is working and sleeve to sleeve also. And like suppose to, sleeve to tip no continuity..
JP
Hemmel
Salut J-P  ;)
I'd start by checking continuity from input tip to 3PDT, then to input of the vero.
Then same with output tip.
I'm guessing the 3PDT has something wrong in its wiring.
Pics would help (if you have time)
Bââââ.
JPGraphX
JPGraphX
rousejeremy
In the future, you may want to use different coloured wires for your connections. It makes troubleshooting easier. Black for ground, red for power, white for signal leads etc.
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
Hemmel
On the 2nd pic, the middle-right lug. Isn't it shorting with the lug under it ?
Also, if tip-tip works, does it still work when you flip the switch ?
Bââââ.
JPGraphX
JPGraphX
Tip to tip when on is not working, (dc unplug) but sleeve does
JPGraphX
JPGraphX
Hemmel
You say you have no guitar signal at all ? Off or on ?
If tip-tip continuity works when switch is off, then you should at least, have bypass signal.
Are you sure your cables are ok ? I mean the instrument cables ?
Bââââ.
JPGraphX
No guitar signal at all, I'll take a look at my guitar cable, but it suppose to work..!
rousejeremy
It almost sounds as if your input is grounded out completely.
Hemmel
Are you checking right now ? In a car ?  I hope you took those pictures while at a red light ;)
I'd like to know also how you connected the lugs on the 3PDT.
If you take your 2nd picture and proceed like this :
A  B  C
D  E  F
G  H  I
Looks like G is connected to I (and I'm still concerned about a short between I and F)
D looks to be input tip
The rest ?
Quote from: rousejeremy on September 04, 2013, 02:55:59 PM
I agree !
Bââââ.
JPGraphX
Im not driving hehehe, copilot :p! Going to a gig in Québec city.
JPGraphX
rousejeremy
Can you check the switch with a meter to make sure it's functioning correctly?
rousejeremy
Did you change anything when you installed the switch? Resolder anything on the board, move ground wires around on the jacks?
JPGraphX
On the board, nothing, but both of the ground was Going to dc, removed one to put on sleeve
