Lost in the jungle of DSP - help
Started by rompelstilchen, September 06, 2013, 07:37:27 AM
Digital Larry
Quote from: rompelstilchen on September 06, 2013, 10:44:47 PM
quiet convincing
is the spincad completely working/finished ?
SpinCAD allows you to chain together different functional blocks.
These blocks need to be developed conceptually and then they need to be coded in Java.
I have implemented a certain number of functional blocks, and yes they do work.
There are some bugs.  There is a lot of room for improvement.
Is it at the level you would expect from a commercial product?  Probably not.
Digital Larry
Digital Larry
Quote from: rompelstilchen on September 06, 2013, 10:47:13 PM
i see there is a dev board, but is there a way to interface a standalone dsp chip with usb for programming, in case i make my own board?
Yes, if you make a board with an EEPROM storing the programs then you can connect something like a PICKit programmer to those signals to write programs to it.
Digital Larry
Digital Larry
#22
Quote from: amptramp on September 06, 2013, 06:52:50 PM
For the OP, would a Raspberry Pi processor work better than an Arduino?  It may not be DSP but it should be a bit more capabel than an Arduino.
Check out AmpBrownie - http://ampbrownie.com/
Also...
http://sourceforge.net/apps/mediawiki/guitarix/index.php?title=Guitarix_Embedded_/_ARM_SoC
Digital Larry
