Resistor value and type
Started by JPGraphX, September 10, 2013, 02:33:50 PM
JPGraphX
Hi!
I'm building a Chimaera and some resistors are carbon and some metal film. On my first build, I forgot to put metal film where it is suppose to. I bought some metal film but there is some value that I don't have.
Example: I got 1.5k metal film, but no 1k. Should I put a 1.5k metal film or I should keep 1k carbon film. What should be closest to original build?
(I want to know want influence more, value or type)
JP
JPGraphX
I have 7 metal film to change on 30 resistors total, should I replace them?
JPGraphX
They are Carbon Film not Carbon Composition.
JPGraphX
pappasmurfsharem
Depends on how close
Carbon film I think has a 5% tolerance, while metal film has 1% tolerance.
So for instance with the 1K
1K Carbon +/- 5% = 950R -> 1050R
1.5K +/- 1% = 1.425K -> 1.575K
Thats almost thats a 150% difference.
Granted it depends the circuit might not be picky, but the carbon film will be closer in this instance.
JPGraphX
If I sont replace the resistor that should be metal film, should I expect à significative différence on sound?
pappasmurfsharem
Quote from: JPGraphX on September 10, 2013, 09:08:33 PM
Supposedly they are supposed to be more noisy but I doubt you will notice.
alanp
Carbon COMP is quite noisy, Carbon FILM is pretty good, and Metal Film is excellent for low noise.
Mojo or no mojo, I never use CC resistors in pedals. (My 5E8A amp came with CC resistors, to be period correct, mostly went with them... even then, I swapped the plate resistors for CF, to reduce noise.) They also drift in value over time.
You're usually pretty safe to use CF or MF interchangeably. Where the value is important (for frequencies, etc), or you're working with a lot of gain, it's better to stick with MF.
i built 2 identical hi gain fet distortions one with carbon, one with metal....
any difference?...not audibly at all. ...the blue just looked better. ;D
they might look better, but we all know they are harder to read ....
as I understand it, the noise produced in resistors is high and white, hissing like. and is dependant on the resistance value, the higher the worser. and is worse in the carbon resistors.
if the carbon resistors aren't in the audio path, or biasing something, they are fine.
" I will say no more "
