Heladito-02 Problem! I don't get chorused signal...
Started by juan_felt, September 13, 2013, 02:04:49 PM
juan_felt
Hi!
I built a Tonepad Heladito 02 (the Small Clone) and I only get dry signal. I adjusted the trimpot to a position in which, when I move the Depth pot, I get the Chours effect, but nothing when it is in a fixed position.
Also, when I measure the LM358 voltages none of them vary.
Has anyone had a similar problem?
Thanks!!
Govmnt_Lacky
Bill_F
I had the same problem after building mine. Turned out, I had a wrong resistor in there, so check all your values. Sounds great now.
juan_felt
Hi, all the resistors are OK. I get the values that vary now, but still the same problem.
In Q1 I have a 2N5089 (instead of the 5087) and the voltages are: E: 5.23 B:0.56 and C:0
Govmnt_Lacky
Quote from: juan_felt on September 13, 2013, 04:06:00 PM
This is NO GOOD.
The 5087 is an PNP transistor and the 5089 is an NPN. You need to use either a 5088 or 5089 there.
