Mosrite Fuzzrite noob question
Started by humanthomas, September 17, 2013, 10:25:12 AM
humanthomas
Hey folks,
I am relatively new to building pedals. I am currently trying to build a fuzzrite clone by the way of this diagram.
http://tagboardeffects.blogspot.com/2010/02/mosrite-fuzzrite.html?showComment=1379381919646#uds-search-results
I did it, and it functions. However, there is an outrageous amount of high end noise (usually louder than the effect itself) Do you guys have any suggestions on what i might be able to do to make this function without this nonsense?
Thanks in advance,
Thomas
midwayfair
"high end noise" You mean hiss, like steam escaping? Or whine, like a high pitched beeeeep?
humanthomas
#2
i would liken it more to a very high pitched steam escaping type noise with a little radio noise mixed in. I used shielded cable from the jack to the switch (ran out so not to the pcb).
midwayfair
Quote from: humanthomas on September 17, 2013, 11:43:20 AM
So the noise is constant?
What's your power filtering like?
humanthomas
Turns out it was the power in my test area... I went to my rehearsal space and it performed perfectly through my rig. So... problem solved I guess!
Thanks anyhow!
LucifersTrip
nothing to do with the noise, but the 22K is missing
always think outside the box
