AD712 OP amp Equivalent ?
Started by HOTTUBES, September 24, 2013, 11:21:06 PM
HOTTUBES
Is there any other op amps that will work in place of the AD712 ?
Thanks !!
HT
In what?
The general idea of opamps is that the amp hardly matters, overall action is set by the parts around the opamp.
To a point. If an opamp is slow, or leaky, or has offset, it can't do fast or high-impedance or precision so well.
The AD712 looks to me a *lot* like a TL072.
It has low offset voltage and high DC gain. Both are critical in some data acquisition systems. Less so in most audio, and hardly-at-all in stompbox work.
But maybe you are doing something that does need a semi-precision opamp?
alexradium
If you are going for the zendrive,tl072 will do just fine,maybe a tad warmer sound.
HOTTUBES
Thanks guys !!   That was just the answer i was looking for ...
