possible mods (aka questions!) for AMZ DC Power Supply
Started by therealfindo, October 11, 2013, 05:15:26 AM
Buzz
Quote from: therealfindo on October 14, 2013, 07:32:37 AM
another question - the diode and fuse... how do I figure out what values / parts they should be?
Personally, I would say leave the fuse out.
For the protection diode use a 1N400x . X being whatever number. A 1N4008 will work just the same as a 1N4001.
I am the Nightrider. I'm a fuel injected stompbox machine. I am the rocker, I am the roller, I am the MIDI-controller!
therealfindo
Quote from: Buzz on October 14, 2013, 08:04:35 AM
Thanks for all the help!
Just realised that without a transformer, these outputs will still all share a ground.. hmm...
Buzz
You could put a filter after the 7809s, like this:
http://www.beavisaudio.com/projects/Huminator/index.htm
Just omit D1, D2 and R2.
Will cut down ripple.
Buzz
Quote from: therealfindo on October 14, 2013, 08:18:11 AM
Yup. The real easy solution is to buy two one spots. Daisy chain all the pedals that play together well on one and give the troublemaker it's own one.
But that would take the fun out of it.
therealfindo
Quote from: Buzz on October 14, 2013, 09:20:26 AM
well.. the powerplant jr I'm running already does have 5 isolated outputs.. but max 130ma. I'm thinking that I run the sensitive pedals via it, and make a second box to go under the board with 4 100ma outputs and one output with 1000ma for the delay.. see how it goes.
