Bad Diode?
Started by Drewmeyer, October 15, 2013, 08:52:55 PM
Drewmeyer
Quote from: Marlowe on October 18, 2013, 01:18:44 AM
Man, I hate that it was the chip. If you don't mind me suggesting the obvious, you might want to consider putting a socket on the board. Not only will it make replacing the chip easier, but you can always try a TL071 in there for it's tonal difference (it makes the Dist+ sound a bit clearer, somewhat like an overdrive).
Sorry I was no help! Marlowe.
Ah, unfortunately no good on the chip. Replaced it and it still doesn't work. What could it be now? Could one of the caps be bad?
now you have to post pictures, so we can see what is.
" I will say no more "
Drewmeyer
Looks like there is no need! Started replacing capacitors and the first one I replaced made it work! Looks like it was a bad capacitor after all! Thanks for all the help, I really appreciate it
see, evertime I threaten with pictures, the poster crumbles and finds the fault! I never get to see anything good.
Quote from: duck_arse on October 31, 2013, 10:10:36 AM
@d_a: you are truly a debugging phenomenom.   :icon_biggrin:
