Does this Millenium Bypass schematic REALLY working?
Started by Rock_on, October 17, 2013, 06:11:10 AM
DIMstompboxes
liagasg
http://www.tonepad.com/getFileInfo.asp?id=76
Check it out.
Offboard Wiring no5 is what you need i think.
Works perfectly in all my builds
Warlord Custom
arma61
Hi
yes, it works, I've ever build a 4 in 1 effects just soldering millenium component' legs together without board.... kinda "dead bug style"  :icon_mrgreen:
bottom right
Ciao
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
Rock_on
Quote from: liagasg on October 17, 2013, 06:58:07 AM
Check it out.
That's my problem. In our area, there's no 3pdt available.
Rock_on
Quote from: arma61 on October 17, 2013, 07:28:33 AM
Hi
bottom right
Ciao
are you using the same one I posted? well if yes, you're lucky! How the **** did you make it come to work?
arma61
Quote from: Rock_on on October 17, 2013, 12:38:41 PM
Hi
bottom right
Ciao
yes! the very same picture, I have it on my book
Luckily ? ;D
some (obvious but worth checking) suggestions
check pin out of the transistor
misure the resistor for the right value
try different LEDs
BTW which effect are you switching with it?
Ciao
Rock_on
EHX LPB-1. would it work with that one? or is there anything I should add to it?
im using a red LED and 330K resistor and 2N3904. pinout confirmed to be correct
Which one of the things in the link you gave are you using? Non of the millennium bypasses there use a 2N3904 or a 330k resistor.
R O Tiree
Firstly, that schem you linked to is not a Millenium Bypass. This is:
I have a suspicion that the vol pot or pull-down resistor on the output of the circuit board might be biasing the transistor into saturation no matter what position the switch is in.  Try something like a 2M resistor and see if you get a better result.
...you fritter and waste the hours in an off-hand way...
arma61
yes, it's called True-Bypas with LED  :D
Reading the note it says adjust the resistor value if necessary for your particular transistor/LED
DIMstompboxes
Errrr that's not millenium, I'm not using this.
I browse in more with your link its truebypass yes with LED using volume resistance (in place with 330k in your case) Try omit the 330k and put 10k series between supply and collector then connect your volume wiper as suggested.
Using 2n3906 PNP if negative gnd OR 2n3904 NPN for positve gnd.
I would recommend source some Jfet just use the millenium.  Me too, before i'm using DPDT with millenium but I got some issue with highgain built. With 3pdt you can ground the circuit input when bypassed.
Good luck.
Rock_on
Ohhh, sorry guys. I just typed in the google millennium bypass and this one came out.
I know, Im one of the 3pdt die hard fan also (fan?). But that's expensive, I would order from another area for that let's say it would cost me 150-200 Php.
millennium bypass would cost me 50-60 php
and this one would cost me 15php only.
see the difference? I can make 2-3 tubescreamer (main) circuit with that money (Im referring to the 3pdt price).
Rock_on
Quote from: DIMstompboxes on October 17, 2013, 07:30:25 PM
Good luck.
10k series? you mean 10 33k? or what?
i'll try this one.
DIMstompboxes
Quote from: Rock_on on October 18, 2013, 11:30:23 PM
Good luck.
i'll try this one.
Here: http://www.diystompboxes.com/smfforum/index.php?topic=64868.0;prev_next=prev
Rock_on
THANKS DUDE!! BIG BIG BIG BIG BIG BIG BIG THANKS!!
so I think I should use the 2n3906 negative ground right?
anyway, my 2n3904 is not wasted.. can you suggest some lpb-1 (simple yet effective) pedal before we close the discussion?
:icon_eek: :icon_surprised: please?
arma61
Rock_on
DIMstompboxes
Quote from: Rock_on on October 20, 2013, 01:43:35 AM
Btw 2N3906 right?
Yes, 2n3906 for negative ground like those Ibanez and Boss pedals powering scheme.
Rock_on
Ah finally! All settled
New circuit to use my 2N3904 and true bypass with led circuit
