Pulldown resistor from positive to negative
Started by armdnrdy, October 20, 2013, 04:40:29 PM
armdnrdy
I'm having a hard time wrapping my head around part of a circuit!
The circuit is the modulation section from the WEM Hyperflanger.
The flanger comes equipped with a Manual/Auto switch (SW2) and a CV input jack (J4) for external control of the modulation. The Manual/Auto switch is depicted in the drawing in the auto position.
The drawing and the user manual call for 0 to +5 volts for the control voltage. The part I don't really understand is when SW2 is in the Manual position..... +5 volts is getting sent through R76 (22K) and a connection is made between R75 and the negative supply.
This looks to be a pull down resistor to negative voltage....but I'm not sure what purpose it serves. The same type of arrangement is seen to the left at P4 (Speed control) with +V coming in and R70 to -VS.
I would like to set up the circuit internally to accept an off the shelf expression pedal but I need a little better understanding of the CV section first.
Any thoughts?
Do you understand opamp summing networks? Do you care? Or do you just want a yes/no?
R75 against R76 mean that EXT must rise above 0.33V before "D" crosses zero (and presumably does its thing). This compensates for external pedals which don't quite go to dead-nuts Zero. You have to come off the end a few percent before anything happens.
R70 is emphatically NOT same type of arrangement. Study the LM13600.
armdnrdy
Quote from: PRR on October 21, 2013, 01:29:35 AM
No...I do not have a great understanding of summing networks.
"Do you care? Or do you just want a yes/no?"
I actually do care. I research every build that I take on. I study the circuit intensely to try to understand the different sections before I commit to a circuit board. When I come across something that I can't identify or am unfamiliar with, I ask questions for clarity.
I do appreciate your reply.
"R75 against R76 mean that EXT must rise above 0.33V before "D" crosses zero"
Just so I understand fully......how did you come up with the .33V?
The opamp stage sums what ever you feed into it through it's various inputs. It's an inverting amp so the gain applied to each input is minus (feedback resistor/input resistor) so for the signal from the ext jack -(R77/76) = -(68k/22k) = -3 so a 0 to 5 volt signal from the ext jack gives 0 to -15 out or 0.33 volts in = -1 volt out.
For the R75 input the gain is -(68k/1000k) = -0.068 x -VS so assuming -VS is -15 volts you get +1 volt out. This is then added to the 0 - 15 volts so you end up with an output that swings from 1 + 0 = 1 to 1 + -15 = -14.
This is ignoring the R78 input any voltage from this is also summed in the same way.
Hope that makes sense.
armdnrdy
Thanks Ian!
That is the explanation that I was looking for.
I'll roll this around for a while until that light bulb is illuminated  :icon_idea:
Oh...and yes...the supply is -15/0/+15
I shudda showed my math.
No. -15V/1Meg balances 22K with +0.33V across it.
-15V/1meg= -15uA
0.33V/22K= 0.015mA = 15uA
Ignore R78 and the Depth network. (If Depth full-down, no effect.)
EXT has to rise above about 0.33V to overcome the 15V/1meg from R75 and move IC16B's output through zero.
I would ass-ume this gives sensible results with external controllers which don't go *quite* to zero.
