Safest place to connect Rate LED on MXR Flanger??
Started by Govmnt_Lacky, November 08, 2013, 01:50:53 PM
Govmnt_Lacky
Looking for the best place to install a Rate LED for the LFO on an MXR Flanger M117.
Thoughts?
Sorry for the HUGE pic!  :-\ MAybe it will help...  ;)
Fender3D
I'm using U5 pin7, 'cause @pin 1 it will tick...
I'm buffering with a NPN, just to be safe...
Govmnt_Lacky
Quote from: Fender3D on November 08, 2013, 02:34:41 PM
Thanks as always Fender!  ;)
That was where I was looking as well but I wanted to confirm.
How are you buffering? Can you provide a drawing?
Fender3D
#3
I can't draw right now, but..
pin 7 > 10K~100K to NPN Base
Collector to +V
Emitter to 4K7 + LED to ground
The higher the base resistor the lower the op-amp loading.
digi2t
#4
Quote from: Fender3D on November 08, 2013, 06:25:20 PM
Collector to +V
Just curious...
Does it matter which side the 4k7 is on? i.e. 4k7 between +V and the collector side. Like this;
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
If you want to try something a little funkier use Fender's buffer suggestion but instead of connecting to Pin7 connect to the wiper of the Width pot. When the width is towards the LFO the LED will flash the same as connecting it to pin7 but with width towards Manual the brightness will show the level of the manual control. I did this in my ADA Flanger and it's pointless but looks quite cool.
digi2t
Sorry, I had to edit my question post above. Screwed up the img part.
Dead End FX
armdnrdy
#7
Quote from: digi2t on November 08, 2013, 07:19:36 PM
Just curious...
The resistor will limit the current no matter what side it is on.
Fender3D
#8
yep but control voltage reference changes
