CHASM REVERB
Started by deadastronaut, November 20, 2013, 12:50:02 PM
@threpwood:  here ya go...sorry guys should have put this in the pdf..(which i will update ok)
Cozybuilder
samhay
Doesn't seem to have the ground trace?
hmmm...i see...
out of curiosity i just wired up a dpdt as above with an unboxed populated working chasm ( plugged into breadboard for testing)...with led ground going to ground pad on main pcb..
led works on/off...but i still get a little verb on bypass...hmmmm....
@george: how did you wire yours?..
for reference.
Cozybuilder
Maybe simplifying to something like this would be worth a try (2N7000 or other MOSFET):
@cozy: we shouldn't need to add anything at all....
me and sam worked on the switching to be totally silent so it didn't bleed /pop when bypassed/on etc...which it did perfectly on my diy pcb prototype...
and chi boy said his fabbed pcb build was fine too...so am curious to see how chi boy wired his switch/led too.....chi boy?...are you out there?..
i have it working ok now, no verb on bypass...
however i get a thump when switching...so am desperate to see chi boys fs/led setup :)
mmlee
#347
I did mine like this and haven't had any issues.
CLR off SW2 - CLR to Anode LED - Cathode LED to SW3
Looks pretty much the same as your PCB at the top of this page
ok, cheers man, cool. 8)
i guess its because mine isn't boxed then...
i'll get it boxed up ;)
threepwood
My finished Chasm. Really love how this sounds Rob. Thanks for a great PCB
Keep up the good work!
Maik
Finished mine yesterday, sounds realy cool but it has a loud whistle.
And with decay full up it sounds nearly like a slapback echo (but with reverb sound).
The whistle didnĀ“t change when I tunr the pots.
With osc on the whistle is incredible loud.
Hi maik..
Something don't sound right with that...
Never had that issue...
check regulator, pot wiring etc, values..
Maik
i'm boxing a chasm up today..
so if you need voltages etc ....
Maik
will be later ok....just had to repaint my etch... ::)
finished my latest chasm reverb ... the 'CELTIC CHASM'
Maik
Damn Rob, that baby looks realy cool!
Cheers man....yea i'm pleased with how this one came out.. :icon_cool:
have you sorted yours yet?...
