Reverb Pedal Options
Started by soupbone, November 22, 2013, 05:02:33 AM
soupbone
I'm  wondering  if  some  folks  have  any  good  builds  for  a  good  sounding  spring  reverb  pedal?I've  played  through  a  T.C. Electronics  Hall  Of  Fame  pedal.Sounded  pretty  nice.I'd  rather  build  one  from  sratch.Any  suggestions  are  gladly  appreciated! :)
Seljer
A good sounding spring reverb, would be a spring reverb :D In which case the only marginally tricky part of it sourcing the tank with the springs, otherwise the circuitry is just a simple amplifier to drive the tanks's input transducer, then another amplifier circuit to bring up the level from the output transducers then a mixer to get your dry/wet ratio right as well as a bit of EQ scattered in between to make sure the reverb is not too muddy or too bright.
Of course, you can't really fit a full sized spring reverb tank into a pedal sized enclosure.
So the options that are left in lieu of actual springs are:
Ice-9
www.stanleyfx.co.uk
