13700 Noisegate/Expander
Started by armdnrdy, December 12, 2013, 11:58:57 AM
disabled_shredder
Hey so I have built the gate only using a 1k for r27 the status led and a tl071 and 2n5088/87 in place of stock transistors q1 is getting to hot to touch I am getting no effected signal but I am getting signal in bypass mode! I do not know what the voltages should be but will measure them and post. Also there are absolutely no solder joints I have checks dozens of times. Does anyone have any idea?
The wild man with a loaded gun and no plan. I'm not held back by rules, just don't know which ones to follow
armdnrdy
You did check the pin out of the 5088/87 right?
They should be facing the opposite way than the BC550s are depicted on the layout.
VahiD
hi , how can change the decay ? i want faster decay plz help
It's going to be either R22 or R17.  I don't know which.
VahiD
tnx its r17
lower resistor = faster decay
VahiD
#105
what about other mods ? can anyone help ?
VahiD
#106
why my clean signal change a bit with this pedal ? i have a bit of noise or gain or someting like this in my clean signal and TR1 is not working plz help tnx
VahiD
nobody can tell me why my signal is change ? if you can plz help me
Tnx all
POTL
Hello I came across this project on madbean's website
Someone compared this loudspeaker with ISP Decimator
Or is there nothing better ISP?
armdnrdy
I received a private message for the project file link that was deleted by dropbox.
As requested:
https://www.dropbox.com/s/9eej1fsdldfs7ct/Noise%20Gate%20-%20Expander%20build%20PDF.pdf?dl=0
Anybody have an idea how to add attack pot to this gate?
jhergonz
a noob question, will the sound entering the LM13700 clip if the signal is too hot, for example, the sound coming from a Active pickups or clean boost.
I know it is recommended to put everything after this Gate, but just, what if?
StephenGiles
On 9v most probably but much less so using a dual + & -15v supply.
